rear main oil seal
  • 1703 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
rear main oil seal
« on: June 03, 2005, 02:15:23 AM »
ok, i've finally got my fly wheel off, and so i will attempt to change the rear main oil seal, only i dont have a clue. i sat under, well, in the tunnel, and had a good look at the back of the motor.
where the seal is, there is a plate that seems to hold the seal and has 5 or 6 bolts holding it in.
now, do i take this plate off to change the oil seal? is it simple as that, or is there more to it?
also, can i leave the sump on, or does the sump need to come off? previous owner/mechanic has sealed the sump with gasket goo in a tube, so if i take this plate off the back of the motor, will i be able to seal it up good again?
if the sump needs to come off, then the front diff needs to come out? that or the motor has to come out.
is it really this much hassle?
thanks
steve
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: rear main oil seal
« Reply #1 on: June 03, 2005, 06:59:09 PM »
ummm you really should buy a manual. then just follow directions from step one.
Not being an ass
I just replaced my clutch and we did it with out the manual for directions but we also missed a step so we had the transmission being held by me while my buddy removed the front driveline. which was step 3 or 4
ooops.
So I recomend the manual.
oh and I think you can get the seal out with a seal remover tool I was reading that section today. if you want I can put all the steps into this thread.
just my .02
« Last Edit: June 03, 2005, 07:01:25 PM by bashzuk »
Mean Green Wheeling Machine
Offline SiKiD_01
  • 574
« Reply #2 on: June 03, 2005, 08:37:37 PM »
tomorrow is sunday, yay, day off, and i will have a look at it, and take it apart too most probably.
if i get stuck, or i find that i dont know what i'm actually doing, i'll let you guys know.
manual is also good, will look to get one next week.
thanks
