Gear problems
  • 11 Replies
  • 4512 Views
Offline WI Zukiman
  • 29
Gear problems
« on: August 02, 2010, 03:36:41 PM »
I dont have a lot of experience with trucks so I need some help. I want to run 35" tires on my samurai but I dont know which gears I should use. I want to still be able to drive it on the road but I dont want the gearing to be so high that I have no use for my lo gears except crawling. I'd rather use my rig for mudding and trail riding than for crawling. Any suggestions?
Re: Gear problems
« Reply #1 on: August 02, 2010, 09:30:40 PM »
5.12 in the diffs and a 6:1 T-case gear set, 4:1 gears aren't low
enough with 35" tires for a true crawl ratio, you will end up smoking
your clutch on the tough stuff
Offline mrhawk
  • 130
  • I Love ZUKS
Re: Gear problems
« Reply #2 on: August 03, 2010, 02:14:53 AM »
I have calminis 5:1 and 3.9 in the diffs with my 35" tires, works great for me.
Offline WI Zukiman
  • 29
Re: Gear problems
« Reply #3 on: August 03, 2010, 12:52:48 PM »
Have you taken your rig in deep mud? and can you get it up to speed easy?
Offline mrhawk
  • 130
  • I Love ZUKS
Re: Gear problems
« Reply #4 on: August 04, 2010, 03:13:02 AM »
I avoid mud for the most time so I'm not really the person to ask :)
I have a carbed 1.6 8v and have no trouble hitting 60mph on the road, it's not a speed monster but it does alright.
A friend has 6:1 and 3.7 diffs with a stock 1.3  on 32" tires, 50 seems to be max for him, and hes working that poor 1.3 pretty hard.
Re: Gear problems
« Reply #5 on: August 04, 2010, 07:36:47 AM »
Keep in mind that a 1.6 has about 30% more power than a 1.3.
The setup I built was a 1.3, with a 1.6 head, 5.38 diff gears and
a 4:1 T-case gear set on 35" MTR's it just had a little too much
trouble crawling and required too much clutch work, and I'm sure
it will need a clutch in a short time if you wheeled it hard on the
rocks all the time
Re: Gear problems
« Reply #6 on: August 04, 2010, 12:15:30 PM »
I run 5.12 gears and a 6.5:1 t-case, works great in low range with 33x12.5" tires.  My next set will be some 35" while the 33's will probably find their way onto another vehicle.
My only issue is a lack of speed in high range.  With the 4 speed I am limited to 55 on a straight, just don't have the RPM's to go any faster.  I would recommend the 6:1 or 6.5:1 as a start, see how you like it.  Then drop down to the 5.12 if needed.
What I think would probably work best is a 4:1, 5.12 gears and a Kicker 3 or Shogun setup with a 1.6L.  Probably an 8 valve just to avoid wiring and go with a side draft.
Offline mrhawk
  • 130
  • I Love ZUKS
Re: Gear problems
« Reply #7 on: August 04, 2010, 01:06:37 PM »
The 1.6 was the best mod I've done. Those extra 300cc makes a huge difference, allot better street performance, and the extra bottom end torque makes crawling nicer.
It's hard to make a zuk that crawls very slow and is decent on the road.  I'd like a little lower low range sometimes, but I dont want lower high range. thinking of a doubler box, but it's out of my budget at the moment, and I'm woried that the extra torque from that setup will kill my stock axleshafts.
Re: Gear problems
« Reply #8 on: August 04, 2010, 10:19:18 PM »
4 Speed??? What are you driving? or did you never try to shift into 5th?
Re: Gear problems
« Reply #9 on: August 05, 2010, 02:40:48 AM »
My SJ-410 still has the stock 970cc 4cyl in it and the stock 4 speed transmission.  Running Sammy t-case and axles though.  :)
Re: Gear problems
« Reply #10 on: August 05, 2010, 09:26:43 AM »
Ohh,  ;D I was wondering about that.
I had a friend that found his car had a 5th gear after he owned it several years,
one day he tried it and was like, Dohh!
LOL
Re: Gear problems
« Reply #11 on: August 06, 2010, 02:37:15 PM »
Well, I do have a 5 speed shifter on it.  It didn't give me the 5th gear though.  :D
