Light Weight crank pulley Rocky-Road
  • 22 Replies
  • 5200 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: June 18, 2004, 04:01:07 AM »
Im just wonderina if anyone has tried it and what they thought of it.
01 GRAND VITARA
jookycola
Re: Light Weight crank pulley Rocky-Road
« Reply #1 on: June 18, 2004, 07:13:11 AM »
looks purdy  ;D
but from my experience with Import Tuners those things can mostly do more bad than good.  the Altenators on these trucks are already seriously underpowered, i personally wouldn't aid in under powering the electrical system any more with an underdrive pulley.
Actually, if you can live without power steering and A/C i found when the belt to those snapped and were no longer dragging on the crank pulley it resulted in a noticeable addition of power...not Vin Diesel like power but i definitely felt a stronger spring in it's step.
I however can not live with out A/C, so i'm back to having my balls clipped (LOL)
Offline JDMCRX
  • 1110
« Reply #2 on: June 18, 2004, 07:41:14 AM »
All i run is Alternator im looking for a bit more power this thing is a dog man
01 GRAND VITARA
Offline Mike71
  • 1449
« Reply #3 on: June 18, 2004, 08:59:15 AM »
i wouldnt do that..the stock alt is realy really really low on the out put scale (it is a trooper however and will last what seems like forever)
i would do spark plugs/wires and an air filter...i did that and i can deff tell a difference in throttle response. i am also going to get a snorkle so that should help the stiffled air box out. also try a high flow cat and exh. that should help ALOT
u could always go the turbo route..thats what im doing  ;D :P
Offline explosivo
  • 3157
« Reply #4 on: June 18, 2004, 09:13:01 AM »
dog man
Quick! Take some pics and send them to the tabloids ;D
omghi2.us[/url]
TITAN
« Reply #5 on: June 18, 2004, 09:27:58 AM »
LOL!!
Offline jerryp58
  • 449
« Reply #6 on: June 18, 2004, 12:09:41 PM »
In the scheme of things (without adding a turbo or supercharger) I don't think there's much you can do that will boost the power of these things too much, but I'm casting another vote for exhaust modifications (header, hi-flow cat, 2" cat back) if you haven't already done that.
Jerry
Offline JDMCRX
  • 1110
« Reply #7 on: June 18, 2004, 01:25:31 PM »
I have a intake and Header and Exhaust and a highflow cam. :(
01 GRAND VITARA
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #8 on: June 18, 2004, 01:49:17 PM »
I would disagree, I have found that a cam will really wake these little motors up, in particular, with intake, and exhaust improvments.
Mac
Offline 1bigtracker
  • 3409
« Reply #9 on: June 18, 2004, 01:51:26 PM »
highflow cam. :(
like a calmini one?
stu
Offline JDMCRX
  • 1110
« Reply #10 on: June 18, 2004, 02:21:18 PM »
yeah i was wondering how much difference there realy is? anyone?
01 GRAND VITARA
Offline jerryp58
  • 449
« Reply #11 on: June 18, 2004, 02:32:09 PM »
I haven't noticed much in the way of intake options (like Calmini's carburetor setup) for these things.  What do some of you have?
Also, what RPM range (low, mid, high) cams are you all choosing?
I guess what I'm thinking is that most upgrades get you low single digit % HP gains (if you're lucky).  Headers are often quoted around 10-15% increase.  With my 80+HP, that'd still leave me under well 100 HP.
Jerry
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #12 on: June 18, 2004, 04:19:44 PM »
I agree with Mac. I put a high torque cam in mine with 2" exhaust(no cat) and put a K&N type cone filter on. I am pushing 32 x 11.5 tires on the highway up and down hills in 5th gear. It has been a huge gain and we are estimating HP at approx 120. My next step is to add a header when cash allows.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline 1bigtracker
  • 3409
« Reply #13 on: June 18, 2004, 04:23:10 PM »
quote]
i have never seen a place that sells a high or low cam.  they all say "mid range". whats so mid range about 5500RPM???
stu
Offline biker
  • 730
« Reply #14 on: June 18, 2004, 04:30:39 PM »
I had mine ground to provide maximum torque at low rpm, I don't need a 5000 rpm screamer
99 Vitara 2wd
10 Gr Vitara
