going from a 8V to a 16V
  • 22 Replies
  • 5415 Views
Offline 1bigtracker
  • 3409
« on: June 21, 2004, 09:13:06 AM »
ok with all luck i will have a second 16V parts tracker.  i have been thinking about swiching to the 16V for the added power and whatever else is better about the engine.  we will be swaping the whole 16V engine in so their won't be any piston issues or anything like that.  what kind of wireing will i have to deal with?  the truck its coming out of is a 5 speed 4X4.  and is their any other things i sould know about before doing the swap?
thanks stu
« Last Edit: June 21, 2004, 09:13:39 AM by 1bigtracker »
Offline idaholwb
  • 772
Re: going from a 8V to a 16V
« Reply #1 on: June 21, 2004, 09:18:43 AM »
 My recommendation is to use the harness and tank from the donor as well. It would make the swap just that much less painful.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline explosivo
  • 3157
« Reply #2 on: June 21, 2004, 09:28:31 AM »
When I asked this very question quite a while ago (not searching, lazy) I was told that the transmissions were the same, but the bellhousings aren't, so you'll need to use the 16v bellhousing...
omghi2.us[/url]
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #3 on: June 21, 2004, 11:05:55 AM »
Unless their is a difference I am unaware of, the 16v & 8v block is the same.  We just swapped one 16v into a Sammy and used the standard TT Adapter kit.   It looked no different then an 8v.  It would be easiest as said, Swap the tank and harness complete.  Once you dive into the swap it will become very clear how far you will need to take the wiring.  I'm not sure how common the different harnesses are and what exactly will plug & play.
Offline Speedracer7c
  • 2210
« Reply #4 on: June 21, 2004, 11:07:52 AM »
Isn't the donor a 4 door, in that case the tank wont fit into your 2 door will it?
Offline 1bigtracker
  • 3409
« Reply #5 on: June 21, 2004, 11:08:39 AM »
do i switch just the pump or the whole tank?  i have my tank mounted in the back where the back seat was.
stu
« Reply #6 on: June 21, 2004, 12:37:22 PM »
If you are EFI the old tank should work,
all you need is Fuel PSI line, Fuel Return Line,
and a Vapor Return line, just hook the lines
up like the old one was
Offline idaholwb
  • 772
« Reply #7 on: June 21, 2004, 01:15:54 PM »
 The  only difference in the bellhousing with any 1.6, is the newer 8v and 16v have extra support braces from the block to the bellhousung. The early 1.6 8v and 1.3 doesn't have the braces.
The tank, you can make the 4 door tank fit in a 2 door. All you have to do is remount it. You don't have to change any fuel lines on the frame. The 2 door tank is 12.5 gallons and the 4 door is 14.5 gallons. I think it would be a double benefit, the right pump and just a little bigger tank.
Just a thought, from someone that has played with the peices to do that very theory.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline 1bigtracker
  • 3409
« Reply #8 on: June 21, 2004, 01:26:37 PM »
i might just put the whole trans and tcase in too.  my trans is starting to get metal in the bottom of it and the same with the t-case.  so it might be the whole thing with a new cluch.
Is their any diffence with the fuel pump itself?  or can i just leave my old one in their.
stu
Offline idaholwb
  • 772
« Reply #9 on: June 21, 2004, 01:54:51 PM »
 I beleive the pump sending unit is the same, just test fit it and go from there.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #10 on: June 21, 2004, 03:18:35 PM »
stu
Awww Yea...
On of my Buddy's Sammys & it's FOR SALE!!!  $3500 OBO  New 35" Boggers on Yotas geared and locked...
« Last Edit: June 21, 2004, 03:22:30 PM by whitfield »
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #11 on: June 21, 2004, 03:22:50 PM »
GONNA GIVE UP THAT LOW END TOURQUE OF YOUR 8 VALVE FOR SOME MORE PONIES AYE STU  ::).......& I THOUGHT YOU DISLIKED THE WHOLE RPM THING IN THE 16 V ;D....  MATTY D.  8)
Offline Mike71
  • 1449
« Reply #12 on: June 21, 2004, 03:29:22 PM »
low end...u mean u spend time away from redline in a tracker? lol i thought the needle never moveid from redline =)
Offline idaholwb
  • 772
« Reply #13 on: June 21, 2004, 06:24:01 PM »
 Funny thing about the 16v. The horsepower and torque are lower in the rpm range than in the 8v motor. More power where you need to use it. Not like a Honda 16v where the power is way up there.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline explosivo
  • 3157
« Reply #14 on: June 21, 2004, 06:35:12 PM »
8v:
Horsepower (SAE net): 80 hp |removethispart|@ 5400 rpm
Torque (SAE net): 94 lb.-ft. |removethispart|@ 3300 rpm
16v:
Horsepower (SAE net): 95 hp |removethispart|@ 5600 rpm
Torque (SAE net): 98 lb.-ft. |removethispart|@ 4000 rpm
omghi2.us[/url]
