Tracker rearend ratio
  • 12 Replies
  • 3654 Views
Offline fatkid79
  • 17
« on: September 22, 2010, 10:58:35 AM »
I am new to this and was wondering what gear ratio is in my 1990 tracker w/an auto trans?  Another question I have is that when going down hills, basically letting it coast, my check engine light comes on but turns off as soon as I give it throttle, any Ideas?
Offline noiseyjack
  • 44
Re: Tracker rearend ratio
« Reply #1 on: September 22, 2010, 11:26:50 AM »
89-98 Tracker/Sidekick Differential Gear Ratios
89     2dr 1.3L carb 5speed man. 5.625
89-95 2dr 1,6L TBI 5speed man. 5.125
89-95 2dr 1,6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 5speed man. 5.375
92-98 4dr 1.6L MPFI 5speed man. 5.125
92-98 4dr 1.6L MPFI 3speed auto. 4.30
92-98 4dr 1.6L MPFI 4speed auto. 5.125
94-98 2dr 1.6L MPFI 5speed man. 5.125
94-98 2dr 1.6L MPFI 3speed auto. 4.30
94-98 2dr 1.6L MPFI 4speed auto. 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
4.625 gears have an 8/37 tooth count
4.30 gears have an 10/43 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
Hope this helps :)
Offline fatkid79
  • 17
« Reply #2 on: September 22, 2010, 03:03:06 PM »
It did, thanks.
« Reply #3 on: September 22, 2010, 05:57:24 PM »
4.62.
EGR or TPS problem maybe?  TPS would be my guess.  Just sitting and idling, does the CEL come on?
Offline fatkid79
  • 17
« Reply #4 on: September 24, 2010, 09:35:38 AM »
No, it only comes on when coasting down hill.  What is a TPS?
« Reply #5 on: September 24, 2010, 08:34:20 PM »
Throttle Position Sensor
Offline fatkid79
  • 17
« Reply #6 on: September 25, 2010, 08:31:59 AM »
Makes sense, it looks as if the TPS has been moved recently.  I just got the tracker a couple of months ago and trying to work out all the little bugs.  I have got a rear bumper and tire rack coming.  The 4inch lift is already installed.  Now a little body work and gears and the 35s are going on.  Thanks for the help.
« Reply #7 on: September 25, 2010, 08:01:45 PM »
Adjust the TPS per the factory service manual, or even a haynes manual, and see if that takes care of the problem.
Offline fatkid79
  • 17
« Reply #8 on: September 26, 2010, 09:12:14 PM »
Its currently adjusted all the way in one direction.  When I got it, the guy told me that it idled high and they could not get it to come down.  It looked like someone was trying to mess with the TPS and all the other adjustments on the FI.  All that was wrond with it was it needed a thermostat, it never warmed up so the computer kept the idle up all the time.  Got that changed and now it idles just fine, now I have to fix all of their "adjustments".
« Reply #9 on: September 27, 2010, 03:48:34 AM »
35's? Better do some serious beefing up to that drivetrain!
Offline fatkid79
  • 17
« Reply #10 on: September 28, 2010, 11:38:18 AM »
Its an auto and all of my wheeling is in the snow for now, not as hard on drivetrain as rockcrawling, if fact it is pretty forgiving.  Maybe someday when things slow down I will be able to add to that and do some rock crawling, but for now I am too busy and the snow is right out my back door from about November to late May.  Currently it has 30x9.5 and I use it as my daily driver.  I will only use the 35s when wheeling, otherwise it will always have the 30s on it.
« Reply #11 on: September 28, 2010, 04:09:05 PM »
You do know your going to have to do some SERIOUS fender cutting, and a minimum of 3-4" of suspension lift as well as 3+" of body lift just to get 35's under it. Your also going to run into a crapload of other issues as well, ultra weak braking power, no pick up or acceleration to speak of,  severely overworked suspension parts and driveline parts. But, if you just use it in the snow, maybe , just maybe you may get away with it. Do yourself a favor, and hit the junkyard and pull a couple of diffs out of a manual and swap them in.
Offline fatkid79
  • 17
« Reply #12 on: October 01, 2010, 03:48:44 PM »
I was already going to do that and I was thinking about installing the tcase gears as well.  Either that or I will dual tcase it. Im not sure yet, one thing at a time.
