T.CASE KEEPS POPPING OUT OF 4 LOW.
  • 2618 Views
Offline camokick93
  • 47
  • SUPPORT OUR TROOPS
« on: October 25, 2010, 05:44:59 PM »
Hi all.My kick's t.case keeps popping out of 4 low when the going gets though while off roading,any ideas? Shifter sheet ??
Thanks
93 4door sidekick,5spd,3in calmini,ome frt coils with 2in spacers,calmini winch bumper,8500 superwinch,calmini front skid,custom rock slidders,custom belly pan,frt ome shocks with upper mount flip,4.24 t-case gears,truck painted camo,hence my user name.I have rear ARB,calmini header exh. combo to be installed soon.FOUR DOORS KICKASS
Re: T.CASE KEEPS POPPING OUT OF 4 LOW.
« Reply #1 on: October 25, 2010, 08:20:38 PM »
I had the same problem, turned out to be worn shifter
dogs in the front of the t-case due to low oil level  :(
I saw the damage when I installed the low range gears
but I also had another case so I used the parts from that
« Reply #2 on: October 26, 2010, 10:35:12 AM »
I had an issue with slightly tweaked t-case mounts allowing the shifter to hit the body.  Pull your rubber cover off and see what the clearance is like.  Nothing like jumping to neutral while climbing some rocks.  :D
Also check the shifter sheet.  It is a pretty cheap part to replace so one of the best things to swap out if you haven't done it before.
Offline camokick93
  • 47
« Reply #3 on: October 26, 2010, 06:40:11 PM »
Hi every one,thanks guy's,Wild,what do you wean by dogs? My shifter looks ok,cant see any particular wear.
Hi Drone,well,the shifter does'nt touch the body,but I find the big boot inside the cab very stiff,seems to pull on the lever
a little,what about the spring on top of the ball of the shift rod,I checked it it's not broken but maybe find a little stronger
spring,would make it harder to move out of gear.I will get a new shifter sheet and try it out.
I'll keep you guys posted.
« Reply #4 on: October 26, 2010, 07:28:28 PM »
Do you have a body lift by chance?
« Reply #5 on: October 26, 2010, 10:04:22 PM »
The dogs are the parts that lock the gears to the shaft, shifting
you into 4 low or 2 high
Offline brenzuk
  • 43
« Reply #6 on: October 28, 2010, 12:27:46 PM »
Mine did this after the body lift.  I bent my shifter, turned the boot around, and considered trimming a little (1/4 inch) from the bottom of my shift knob.  Never had to trim the shift knob though.
Offline camokick93
  • 47
« Reply #7 on: October 28, 2010, 04:19:35 PM »
Hi,I have no body lift on my kick,I'm pretty sure the internals of the case are not worn out,every thing looked fine when I did
the 4.24 low mod...but then again.
Yes maybe try to bend the shift lever a little bit and I'll order a shifter sheet and see what happens.
Thanks dudes,I'm open to suggestions
« Reply #8 on: October 28, 2010, 09:50:44 PM »
If you don't have the good and worn parts side by side
you really will not notice that the one is bad
