Oh no I think I have a problem....
  • 2538 Views
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« on: October 29, 2010, 06:13:04 PM »
    On the way home yesterday from work my 93 4 door auto trans Sidekick started to miss and the overdrive lite on the dash was flashing. I stuck it into neutral and reved it and it seemed ok so I dropped it into gear and limped it into a parking spot across the street. I shut it off and popped the hood thinking I broke a belt and I looked and all the belts are ok. I jumped back in and started it and everything seemed ok, no lite and no miss. So I drove the two blocks home and it did it again ! Has anyone else ever had something like this happen ?
                Ed
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Re: Oh no I think I have a problem....
« Reply #1 on: October 29, 2010, 09:04:15 PM »
What engine?
Offline FireCkrEd
  • 246
« Reply #2 on: October 30, 2010, 09:02:42 PM »
16 valve
« Reply #3 on: October 30, 2010, 09:17:15 PM »
You might have a bad crank position sensor, it's located in the
oil pump housing and in the U shaped section at the front of the
engine, clean it from any dirt or oil, and see if the connector is
clean and not damaged
« Reply #4 on: October 31, 2010, 11:14:21 AM »
I thought the position sensor was in the back of the engine on the odbc I 16 valve engines.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #5 on: November 02, 2010, 07:43:38 AM »
I didn,t know obd1 16v had one at all i didn't see one when i put my motor in ???
« Reply #6 on: November 02, 2010, 12:32:34 PM »
How that work?  You have to send a structured query to know what position the crank is in ?  ;)
« Reply #7 on: November 02, 2010, 01:42:10 PM »
I thought they used a camshaft position sensor on the distributor.  I don't know much about the 95's though, just that the don't have one on the oil pan like the 96's.  :)
