landcruiser axles
  • 23 Replies
  • 8490 Views
Offline airmanwilliams
  • 913
landcruiser axles
« on: March 08, 2011, 09:23:59 AM »
I have axcess to landcruiser axles and wondered if anyone can enlighten me about the swap of these axles into a samurai. I just rebuilt my axles and put in 5.12 gears with a hybrid housing in the rear but now am able to get a good deal on some landcruiser axles and am looking to see how much work it might take to swap these granted while going to school it might be a long drug out project of rebuilding and cleaning them.
1993 4door Suzuki Sidekick JX
Offline ASI H8
Re: landcruiser axles
« Reply #1 on: March 08, 2011, 10:10:17 AM »
I'm going to be stepping into a Yota swap soon myself.  From what I have been seeing, Sky makes a front axle kit.  It looks like it is a basic SPOA.  Big issues will be spring perch alignment and steering geometry.  There is a guy on Zuks of KC that is doing the same swap.  http://www.zuksofkc.us/index.php?topic=859.0
What year are your axles?
Offline Jluck
  • 1389
  • 40
« Reply #2 on: March 08, 2011, 11:12:02 AM »
Cruiser axles are different than pickup axles from the knuckles in. They work good for sammys due to the off set rear. Go for it! That's what I have in mind for my kick too.
What series axles are they? 40,60,80...?
You will have to fab up your own mounts or you could start with a 40 or 60 series shackel reversal if you are using leafs.
  • 913
« Reply #3 on: March 08, 2011, 11:19:21 AM »
im waiting for my buddy to go back and check them out and tell me what the specs are like the series, year and more. From what I gather right now I have to cut the old spring perches off and put new ones on for the samurai, get a disc break conversion for the front and thats all I know so far.
what am I going to have to get for steering? with these being on a daily driver what do you guys think I should get for transfer case gears? Anything else I need? anyone seen a write up they have a link to for me?
Offline Jluck
  • 1389
  • 40
« Reply #4 on: March 08, 2011, 11:55:54 AM »
They must be 40 series if there drum braked. I don't know about there perch width. You can use toy pick up ott arms.or somewhere I saw cruiser ott as a package.
You will need t/case gears! Factory cruiser will have 3.73or 4.10's
« Reply #5 on: March 08, 2011, 02:02:48 PM »
You can also swap over to the Mini-Truck outers on the front end.  I just don't know how.  :D  An FJ-40 from my club runs the different outers and brakes from a Corvette on all 4 corners.
  • 913
« Reply #6 on: March 08, 2011, 02:04:59 PM »
ok even though I have alot of post I am still a newbie with all this and have to ask, what are outers?
Offline Jluck
  • 1389
  • 40
« Reply #7 on: March 08, 2011, 02:07:19 PM »
steering knuckles out. on the end of the axles there are "balls" and the knuckles (outers) go on to the balls.
the part that OTT steering arms bolt too.
« Last Edit: March 08, 2011, 02:09:12 PM by Jluck »
  • 913
« Reply #8 on: March 08, 2011, 02:08:30 PM »
thanks jluck this is going to be a long process of getting to learn and know everything.
« Reply #9 on: March 08, 2011, 02:09:47 PM »
You never know everything.  But you can learn an awful lot from mistakes.  :P
  • 913
« Reply #10 on: March 08, 2011, 06:07:35 PM »
ok so I talked to the guy and all he knows is that they are early 70's landcruiser axles and nothing else. is there a way to tell if they are 40 or 60 series or are they definately 40 series being drum brakes front and rear and early 70's?
Offline ASI H8
« Reply #11 on: March 08, 2011, 06:47:29 PM »
  • 913
« Reply #12 on: March 08, 2011, 06:57:44 PM »
thanks for the info and help guys. do you all think im wise to get these two axles for $200 and rebuild them versus paying about $300 for one regular axle and rebuilding a couple of those to put under?
« Reply #13 on: March 08, 2011, 09:22:36 PM »
i have a set of those laying in my yard, I was going to put them on mine until I found out how heavy they are and went to toy pick up diffs. the front shafts are the size of base ball bats.
Offline ASI H8
« Reply #14 on: March 09, 2011, 05:47:50 AM »
$200 for two axles, matching, Front and Rear?  That is tough.
Two things I would consider:
1. What I expect out of the axles and
2. What would I have to do ($$$$$$) to get the axles to my expectations
Take the path that works best for you!!
