Samurai Carburetor
  • 1852 Views
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
Samurai Carburetor
« on: July 07, 2011, 03:35:05 PM »
I have a 86 Samurai 1.3 carbureted, it was running to rich so I checked the sight glass and the fuel level was to high. So I took the top off and lowered the float level, put it back together and checked ,it was too low. So now I've done this a bunch of times but now the fuel level will only reach the bottom of the sight hole, no matter where I set the float it won't go any higher. It seems to drive ok but I would like to get it right. I've replaced the float and the needle and seat and have run out of ideas. It has a new fuel pump and filter on it. Any ideas?????   Thanks
Re: Samurai Carburetor
« Reply #1 on: July 08, 2011, 10:38:42 AM »
if the float hooks to the top of the carb you could try flipping the top upside down and setting it that way.
Offline weldboy
  • 91
« Reply #2 on: July 08, 2011, 10:57:41 AM »
I have turned the top upside down, the FSM says to set it at 8mm, I've set it a 4mm, that's as high as I can raise it before it's hitting the top of the carb.  ???
