Body lift
  • 2413 Views
Body lift
« on: November 06, 2011, 02:19:56 PM »
What all do i need for a 2 In body lift. i have the spacers but dont know what else is needed like extentions or how many spacers is there on the truck?
Offline talonxracer
  • 1284
Re: Body lift
« Reply #1 on: November 07, 2011, 07:14:58 AM »
From what I understand, the fuel tank filler hose and brake lines need to be watched as you raise the body off the frame, that is about the only items to watch out for. I think a few wire harnesses may need their retaining clamps loosened to allow the lift
Offline MUD CHILD
  • 355
  • 9
Re: Body lift
« Reply #2 on: November 07, 2011, 08:11:40 AM »
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Re: Body lift
« Reply #3 on: November 07, 2011, 04:51:17 PM »
that's a nice kit. are there 8 body mounts? how many does a trackick have?
Offline beagle..t
  • 1239
  • 16
Re: Body lift
« Reply #4 on: November 07, 2011, 08:21:54 PM »
drivers side front retainer clip for frt brakes has to be removed, fuel filler hose just has too be loosened shifters should have a piece of rod welded on so that everything goes back together and doesn't look ghetto and steering bolt has to be loosened off and only do one side at a time or your vehicle wont bolt back together properly thats all i can remember
Offline MongooseVRX
  • 64
    • M.O.S. forum
Re: Body lift
« Reply #5 on: November 08, 2011, 05:03:45 AM »
Yes, 8. There is a spot on each side where there is a contact point between the body and frame. It is right under the rear seat(on top of the frame where it arches up over the rear axle)
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
Offline MongooseVRX
  • 64
    • M.O.S. forum
Re: Body lift
« Reply #6 on: November 08, 2011, 05:04:55 AM »
Oh, and I'm assuming you have a 2 door...
Minnesota Overland
Offline MUD CHILD
  • 355
  • 9
Re: Body lift
« Reply #7 on: November 08, 2011, 05:07:41 PM »
Yes there are 8 body mounts and 4 body supports. Everything you need to install is supplied in the kit except bumper relocation brackets. Kit comes with instructions as well.
Re: Body lift
« Reply #8 on: November 08, 2011, 06:14:30 PM »
I Currently have a 2 door tin top. but trying to trade my dad for his 4 door sidekick. Just because I have a 10 month old son and 4 door makes it much easyer to put him in and out of.
