Headlight wiring?
  • 4 Replies
  • 3207 Views
Offline Cheeto
  • 55
Headlight wiring?
« on: January 14, 2012, 10:43:24 PM »
My Tracker came to me without lights or plugs (wrecked). I did a quick-fix and got some lights set up for my low beams but now I'm working on high beams and am a little confused. Does anybody have the wiring diagram? Are these constant hot? How does that work with a dual filament bulb with only 3 wires on the plug? Why do I still have 2 ground wires after I've used 2 for the low beams?
Offline fordem
Re: Headlight wiring?
« Reply #1 on: January 15, 2012, 09:38:37 AM »
The bulbs have two filaments with a common connection - this is how all dual beam headlight bulbs that I have seen are wired.  You can either wire the common connection to ground and apply +12v to the remaing connections one at a time (most US domestics seem to be wired this way), or you can wire the common connection to +12V and apply ground to the remaining connections one at a time (which is how Suzuki and many other japanese manufacturers do it).
I'll post a Suzuki diagram in a bit - the Tracker should be similar.
Edit.
I've attached a PDF with the headlight wiring of a 99 Vitara - it's typical of how Suzuki wired most of their vehicles - if you have a 98 or earlier, you probably won't have the relay or the diode - it should be close nough that you can use it as a guide.
« Last Edit: January 15, 2012, 12:00:08 PM by fordem »
Offline Cheeto
  • 55
« Reply #2 on: January 15, 2012, 09:56:15 AM »
... or you can wire the common connection to +12V and apply ground to the remaining connections one at a time ...
Good point. I've been playing with L.E.D.s so much lately (which can only be wired one "direction") I forgot that filament bulbs don't care about polarity. They can take power through the contact or the base as long as they have a complete circuit.
Thanks.
Offline Cheeto
  • 55
« Reply #3 on: January 15, 2012, 02:10:13 PM »
Should of specified that it's a '96.
Thanks for the PDF. Gave you some "tech rep".
If I'm reading that correctly power comes in on the w/r and w/bl (I didn't realize each headlight had separate feeds). The grounds are triggered as follows. r/w triggers low beam and r triggers high beam, both through the dimmer switch.
w=white
r=red
bl=blue
If I'm off on anything let me know, plan to attack this tonight.
Offline fordem
« Reply #4 on: January 15, 2012, 05:14:56 PM »
That pretty much describes it - and thanks for the t/r
