Found electical problem
keith
1176
3
April 30, 2004, 01:42:25 AM »
Last weekend I posted about my headlights and interior lights and radio not working.  I took the Tracker to a local shop and they found the wires leading to the fuse block under the hood were severely coroded.  They said the wires fell apart in their hand.  The fuse block only costs $40 but a wiring harness will have to be fabricated and that could be 4-6 hours in labor.  Hopefully this solves all my problems.
Last Edit: April 30, 2004, 01:43:02 AM by keith
HotRod
4334
2
95 Tracker
Re: Found electical problem
April 30, 2004, 09:24:28 AM »
Good luck
keith
1176
3
May 01, 2004, 01:51:52 PM »
I picked up my Tracker from the shop today. The fuse box was the source of the lighting problems. It cost way too much to fix though. The idle problem appears to fixed also. I think the starter is going though. It has been starting, but the starter sounds weak. Does anyone know where I can get a cheap starter?
wildgoody
8134
67
Reply #3 on:
May 01, 2004, 01:58:44 PM »
Check your charging system and battery condition.
Weak starter could be weak battery
keith
1176
3
Reply #4 on:
May 01, 2004, 02:08:58 PM »
The charging system puts out between 14 and 15 volts when idling fast. The battery is one week old, but is a Wal-Mart cheapo.
wildgoody
8134
67
Reply #5 on:
May 01, 2004, 04:34:26 PM »
Amps not Volts charges a battery, you need
a load test on the Batt and the system, could
be a weak battery.
The thing that goes bad in a starter is the solenoid,
then the brushes sometimes.
good luck
keith
1176
3
Reply #6 on:
May 02, 2004, 12:19:52 PM »
Today I removed the starter and took it to AutoZone for testing. It tested fine. They cleaned up the terminals. I put some dialectic grease on them when I put in back in. Since then it is spinning quick and starting!
wildgoody
8134
67
Reply #7 on:
May 02, 2004, 01:13:12 PM »
I love a quick, cheap and dirty fix
LOL
jerryp58
449
Reply #8 on:
May 02, 2004, 01:24:27 PM »
That's great!
Jerry
1990 Geo Tracker, 2-Door Hard Top
Speedracer7c
2210
Guess she ain't stock no more!
Reply #9 on:
May 02, 2004, 03:32:32 PM »
So what are you going to do about all the other problems?
