WTB Power window parts
  • 22 Replies
  • 5207 Views
« on: March 06, 2012, 09:15:27 AM »
Just putting out a feeler to see if anyone has any power window parts for a 95 trackick 2 door. I'm thinking of adding power to my windows and would need everything, regulators, wiring and switches. Let me know what you have. Thanks, Mike.
Offline RJkick
  • 634
Re: WTB Power window parts
« Reply #1 on: March 06, 2012, 10:27:40 AM »
I have a motor for the driver's side window if interested
I can check to make sure what the number on it as well if you need it
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #2 on: March 06, 2012, 01:01:31 PM »
I have everything from my 4 door that I just parted out.
Switches, Regulators, some of the immediate wiring (near the plugs and such), Power Locks too.
« Reply #3 on: March 06, 2012, 03:25:20 PM »
Rj, not sure what the number would be, but just in case,
zuksofhazzard, I need to find out of the regulators are the same 2 and 4 door. Sending you a PM
« Reply #4 on: March 07, 2012, 04:20:16 PM »
Still lookin for the 2 door stuff
« Reply #5 on: March 11, 2012, 05:33:13 PM »
and will continue looking  :(
« Reply #6 on: April 05, 2012, 04:33:40 PM »
Anyone?
Offline locjaw
  • 2045
  • 22
« Reply #7 on: April 07, 2012, 06:18:31 AM »
Anyone?
im not sure aftermarket units wouldnt be a easier install. i saw a samurai with them and they were sleek and sexy. not a lot of 2 doors i have ever seen with p/w..
« Reply #8 on: April 07, 2012, 06:38:36 AM »
I actually picked up a aftermarket kit but after examining it I came to the conclusion it wouldn't last long. It uses plastic gears to drive the window crank shaft. Not a bad idea in itself, but the quality of the gears was suspect IMO. The teeth were very shallow and looked like one accidental over run would strip them. I sent it back. If it weren't for the low quality plastic gears, the rest of the kit looked great for the price, $95. Included everything, multiple switches and combinations, wiring harnesses to fit just about anything, and enough of those plastic gears to make up any combination, I mean there was a LARGE bag of gears. I did find on ebay, new, stock aftermarket replacement power window regulators for 2 door Trackicks for only $59 ea. Of course there are the switches and wiring to figure out.  I'm slowly loosing interest, though it would be nice to not have to streach over to open the passenger window. Good thing these trucks are small enough for me to still be able to do that  :laugh:
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #10 on: April 07, 2012, 07:39:15 AM »
...actually, it can be done with the 5-wire switches and relays, but I have usually done with 3-wire switch and this arrangement... (PDL the same with cheap actuators, btw)
« Last Edit: April 07, 2012, 07:47:23 AM by ecoast »
« Reply #11 on: April 08, 2012, 06:15:56 AM »
Hey John, thanks again. I'm glad I got to take a look at those universal ones at least, but it did cost me $14 for that look. I have a bag full of relays, so wouldn't need to buy any of those. Those switches are CHEAP!!! I think I'm gonna spring for it. Thanks for the schematic too. I WILL be calling you  when I run into wiring issues. But really, I should be able to figure this out.  ::)
« Reply #12 on: April 08, 2012, 06:19:50 AM »
Aren't those just momentary , on/off/on switches? If so can any 3 wire momentary on/off/on switch work? Reason I'm asking is I have a bunch of those too. same ones used to run shopping center register belts.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #13 on: April 08, 2012, 09:21:47 AM »
yes, momentary
spdt
afa switches, anything similar would work--
vw, audi, porshe, all use the same & are nice...or buy the type I showed you, with or w/o surface mount housing, or cut two into center console w/dremel & 1/8" bit to snap in...
afa pdl, just get the cheapest you can; looks like 6 bucks ea. or so (shipped!)
we put hundreds of these in = no prob (...just trust me!)
you might put one switch in console; why would you need two?
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #14 on: April 08, 2012, 09:22:40 AM »
might order a cheap remote keyless entry at the same time so it'll be neater than going back in later...
