Vibration at 60+ MPH
  • 47 Replies
  • 11388 Views
« on: April 27, 2012, 07:59:09 AM »
« Last Edit: July 13, 2012, 02:40:21 PM by Warn Industries »
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Offline talonxracer
  • 1284
Re: Vibration at 60+ MPH
« Reply #1 on: April 27, 2012, 08:13:19 AM »
I would suggest having the tires/wheels rebalanced and checked for out of round.
No need to find hubcentric rings, they would not help at all and probably induce even more issues as nothing is machined to be hubcentric, the Zuki's are stud centric.
Also weak, whimpy suspension link bushings can allow an oscillation to develop.
« Last Edit: April 27, 2012, 08:25:44 AM by talonxracer »
« Reply #2 on: April 27, 2012, 08:24:11 AM »
Good to know about the stud-centric deal.
I'll bring the wheels/tires in and have them looked at.
- Andy
Offline lv2fsh
  • 312
  • 19
« Reply #3 on: April 27, 2012, 10:00:58 AM »
I vote u joints. After you run it for a while, fell them.A bad one will be hot.
Offline boomer35
  • 30
« Reply #4 on: April 27, 2012, 02:52:47 PM »
I recently replaced my U-joints and forgot to mark the driveshaft.  If the driveshaft isn't mounted correctly, it gets out of balance (you can see the little rectangle weights welded to it) and causes a really odd vibration like someone is pumping bass through a subwoofer.  I just removed the shaft, rotated the mounting point by one each time, and found one that made the vibration go away.
« Reply #5 on: April 27, 2012, 05:36:06 PM »
It could be broken cords in your tires.  Tires do not need to be that low on tread.  I had both front tires on my Grand Prix break the cords, and took it to a Garage to find the problem.  Replaced all the tires and problem went away.
Offline lv2fsh
  • 312
  • 19
« Reply #6 on: April 27, 2012, 05:50:20 PM »
There are phase alignment dots on the driveshafts. Takes the guesswork out of it.
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #7 on: April 29, 2012, 12:16:44 PM »
Check the rear shocks. Mine did just that when I had a blown shockabsorber.
Very soft shocks combined with a bad balanced tire can also get the car to shake.
Offline boomer35
  • 30
« Reply #8 on: April 30, 2012, 05:59:11 AM »
Wish I'd known about those phase alignment dots before :(  Where are they located?  I wasn't looking for them when the shaft was off, so I didn't notice them.
Offline talonxracer
  • 1284
« Reply #9 on: April 30, 2012, 07:17:24 AM »
Is there much slop in your slip yoke/ output shaft fit, output roller bearings shot?
« Reply #10 on: April 30, 2012, 04:14:07 PM »
Took the Kick to the dunes this weekend. Drives just fine at 60mph and under, but over that, you get more and more vibration.
I'm going out of town, but hope to bring it in to the tire guy next week and start narrowing this down.
- Andy
Offline djjiz
  • 48
« Reply #11 on: May 01, 2012, 03:16:53 AM »
Was the drive shaft lengthened after the lift?
I'll kiss your moms dildo for $10
« Reply #12 on: May 01, 2012, 11:46:32 AM »
- Andy
I keep checking to see what the problem was.
« Reply #13 on: May 07, 2012, 03:08:58 PM »
No ... should it be for only a 2" spring lift?
Still haven't had a chance to bring it in for the tires. Hopefully this week.
- Andy
Offline djjiz
  • 48
« Reply #14 on: May 07, 2012, 07:23:41 PM »
Mine did after a 2" lift.
Brand new tires and u joints before the lift and it made it obvious for me. Just a cheesy spacer and my highway vibrations went away.
