Toyota axels?
  • 1955 Views
Offline stanekb
Toyota axels?
« on: April 27, 2012, 09:58:26 PM »
Anyone know what needs to be build, bought and or modified to put in Toyota axels?
( I am wanting to do this because the 82 SJ is hard to find parts, do I want to go with more common front and rear axels, if you have any other suggestions I'm all ears!)
Thanks
« Last Edit: April 27, 2012, 10:09:43 PM by stanekb »
Offline Boxcar
  • 936
Re: Toyota axels?
« Reply #1 on: April 28, 2012, 05:57:48 AM »
CJ 5 axles require much less modification to swap into a Sammy. Aspecialy pre 71 s. They are nearly a direct fit.
 Corect off set and width.   ...Boxcar...
God Bless
Offline stanekb
Re: Toyota axels?
« Reply #2 on: April 28, 2012, 07:34:25 AM »
Thanks
Re: Toyota axels?
« Reply #3 on: April 30, 2012, 02:55:53 PM »
Are you looking at putting a new motor in as well?  If your just looking for slightly larger axles with easier to find parts I would track down a set of Samurai axles.  That will give you disk brakes in the front, access to a lot more locker options and they are 3" wider then your stock SJ-410 axles.
You will need to re-weld your spring pads but they can be made to work with your stock springs without to many issues.
Offline stanekb
Re: Toyota axels?
« Reply #4 on: May 01, 2012, 12:49:59 PM »
Perfect, thanks
