Is this a common 1.6 block failure?
  • 3037 Views
Offline Khodabear
  • 155
  • Littleton Colorado
« on: August 19, 2012, 10:03:50 AM »
No bearing spin. No indication of overheat. Crank is within spec.  Bores are well within spec.
1997 Tracker
1997 X90
Offline Capt
  • 738
  • 28
Re: Is this a common 1.6 block failure?
« Reply #1 on: August 19, 2012, 07:59:41 PM »
Just curious, which main bearing is it?
Does it line up near the motor mounts?
It might not be an internal stress that cracked the journal.
CAPT
« Reply #2 on: August 20, 2012, 11:12:04 AM »
I would say it is not common.  IDK that I have even ever heard of a 16V cracking a journal.
Offline Khodabear
  • 155
« Reply #3 on: August 21, 2012, 08:17:34 AM »
CAPT
#3 - yes - adjacent to motor mounts. Interesting observation...
1997 Tracker
1997 X90
« Reply #4 on: August 21, 2012, 05:03:20 PM »
Is this from the truck you drove on the Zukiworld adventure?
Offline Khodabear
  • 155
« Reply #5 on: August 21, 2012, 05:18:34 PM »
Nooo!
That one is just fine - although I haven't put it up to see the biffs and bumps from the rocks  :o
This one is from a 4 door that I'm parting out.
1997 Tracker
1997 X90
Offline zorproducts
  • 54
« Reply #6 on: August 24, 2012, 07:19:13 AM »
A lot more common than you think. Normally located between Cylinder 1 and 2 that is a crack caused by 2 things.
#1 Not having the main cap girdle installed
#2 It did get over temped on one occasion.
FYI,
16v plenum sensors are incapable of reading steam on a C-H gauge. Yes even the Factory gauge. The needle does go up for a second during a hot condition and then immediately drops to cool. ALWAYS use a real water temp gauge and sensor with 16v. They are unforgiving when it comes to being overheated. The good news is that that crack will not affect anything, It goes no where. Does not hurt Crank and/or main journal bearings.
MY
