Axel Rotation
  • 39 Replies
  • 8611 Views
Offline explosivo
  • 3157
Axel Rotation
« on: March 20, 2004, 01:07:02 PM »
I've heard it mentioned a couple times here... what is it exactly?
omghi2.us[/url]
Offline 1bigtracker
  • 3409
Re: Axel Rotation
« Reply #1 on: March 20, 2004, 01:38:12 PM »
its when you rotate you pinon upword to get your driveshaft stright with the pinon.  it will also incease flex if you do it with F-150 shocks.  If you go to "Article Archive"  you can go down to the tech section and see how its done.  its in the small section on the right side with HAGEN on top.
stu
Offline explosivo
  • 3157
Re: Axel Rotation
« Reply #2 on: March 20, 2004, 01:39:29 PM »
omghi2.us[/url]
Offline 1bigtracker
  • 3409
Re: Axel Rotation
« Reply #3 on: March 20, 2004, 01:41:25 PM »
no prob.  i have been wanting to do it for a while now just haven't had the time.
Stu
Offline rockrat
  • 196
  • Got Ringr
Re: Axel Rotation
« Reply #4 on: March 23, 2004, 01:07:26 PM »
You should never point the pinion at the t-case output unless you intend to either put a cv shaft on the rear or purchase alot of u-joints. Yes you get less bind under droop but with a standard shaft you will eat joints, on a regular basis.
Offline 1bigtracker
  • 3409
Re: Axel Rotation
« Reply #5 on: March 23, 2004, 01:35:28 PM »
but what about the front tracker drive shaft.  it is pointed right at the output and doesn't have any vibes or u-joint ware probs.  i'm i missing somthing?
stu
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Axel Rotation
« Reply #6 on: March 23, 2004, 02:43:05 PM »
What Rockrat is trying to say is that your diveline angles must match if your using a standard one u-joint each end driveshaft. Another words if the transfer case to diveshaft angle is 15 degrees, then the other end needs to be -15 or -17 degrees. If you run a double cardan joint (cv) then you must make it 0 or -2 degrees at the rear.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Re: Axel Rotation
« Reply #7 on: March 23, 2004, 03:05:25 PM »
Ya, That sounds like a mis-stated piece
of information, the Axle Rotation corrects
the effect of the lift on the U-Joints, reducing
the angle of the U-joints, which helps their
life.
The rotation I did keeps the pinion pointed at
the output on the trans at all stages of extension
and compression, and offers a little more clearance
for bigger tires, adds about 1 inch, maybe more.
Offline pbgbottle
  • 76
Re: Axel Rotation
« Reply #8 on: March 23, 2004, 03:17:17 PM »
i think the article is about
OVER-ROTATING THE DIFF.   up!
not rotating it straight at the t-case .point the diff slightly above the t-case and set proper u-joint angles .
  I THINK ?
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline rockrat
  • 196
  • Got Ringr
Re: Axel Rotation
« Reply #9 on: March 24, 2004, 10:32:45 AM »
Always set the pinion a dgree or 2 below the output, that cancels out spring wrap which will turn the pinion into alignment.. Never above the output
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Axel Rotation
« Reply #10 on: March 24, 2004, 01:11:45 PM »
Spring wrap on a trackick?  ::) I would never do this on a sami because of the spring wrap but a trackick is 3 link. Their is no spring wrap. Ive been doing it for 5 years and almost 300,000 miles between my two Trackers... I can assure you it doesnt eat u joints, axle bearings, Ring or pinions or anything of the kind. All RPM Trackers have their rear axles over rotated as shown in the artical. Not one Tracker has had a single u joint go bad or anything remotely related to this mod. I recomend this mod to everyone with a lifted trackick.
Mike
Offline Mike71
  • 1449
Re: Axel Rotation
« Reply #11 on: March 24, 2004, 01:20:08 PM »
im totaly confused after reading this thread..i need to go soak my brain now lol
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Axel Rotation
« Reply #12 on: March 24, 2004, 01:22:19 PM »
LISTEN TO WHAT MIKE HAS TO SAY...HE'S BEEN DOING THEM FOR LONG TIME NOW AS HE STATES WITH NO PROBLEMS......I'D DONE IT BY NOW BUT ONLY HIGH PRICE BUILDERS AROUND HERE...AND THE ZUKE FUND IS BOTTOMED OUT STILL  :(
Offline 1bigtracker
  • 3409
Re: Axel Rotation
« Reply #13 on: March 24, 2004, 01:49:08 PM »
we have conflicting storys????  whos right?  i vote mike.
Stu
Offline DirtDevil
  • 317
  • Island4x4.com
Re: Axel Rotation
« Reply #14 on: March 24, 2004, 02:13:11 PM »
where is that hagen artical i cant find it ???
