Bracket Question
  • 2328 Views
Offline RJkick
  • 634
Bracket Question
« on: October 12, 2012, 10:06:13 AM »
After changing my head gasket I am down to this bracket.  I found a place to mount it back on to but it just doesn't look right.
Can anyone let me know where this bracket goes?   Thanks
Re: Bracket Question
« Reply #1 on: October 12, 2012, 10:30:39 AM »
it's kind of hard to see it, could you take the bracket back off and take a better pic of it?
Offline talonxracer
  • 1284
« Reply #2 on: October 12, 2012, 11:14:38 AM »
Here is the best pic I have,
It looks like you have it upside down.
« Last Edit: October 12, 2012, 11:18:11 AM by talonxracer »
« Reply #3 on: October 13, 2012, 04:35:44 AM »
That' right and there should be a plastic cover that attaches to that bracket with three small bolts, two on that bracket and one on the throttle body housing.  I don't think that bracket can be mounted upside down, wouldn't fit.
Offline talonxracer
  • 1284
« Reply #4 on: October 13, 2012, 05:59:15 AM »
Yes it is installed upside down, the two holes for mounting the plastic cover should be to the top of the bracket, not the bottom. I'll take a pic in a hour or so when it warms up a bit and I get outside and remove that cover on my kick.
Offline RJkick
  • 634
« Reply #5 on: October 14, 2012, 08:07:37 AM »
Yep, I had it upside down.  Nothing mounted top the top of it though.  I think the Zuk lost the plastic piece somewhere between 92 and 2005 when I tokk it over
Thanks
As usual the collective knowledge of the board knows all
Now I am going to try timing er and hopefully get er back on and off the road
