Groan on articulation?
  • 3302 Views
Offline Lwing
« on: August 16, 2015, 07:38:30 PM »
Hi there,
I have a 96 sidekick , Altered Ego 4.5" suspension lift with ARB lockers added two weeks ago. Just recently on articulation at slow speed there seems to be a groan from the front end. Have been running a lot of washboard road lately.Looking for some suggestions to help point me in the right direction.
Thanks
lwing
« Last Edit: August 17, 2015, 02:47:11 PM by Lwing »
Offline Lwing
Re: Groan on articulation?
« Reply #1 on: August 17, 2015, 02:48:02 PM »
Don't know whose engine that is
« Reply #2 on: August 17, 2015, 05:22:59 PM »
Thats been happening occasionally on this site ( unknown pics showing up in posts)  As far as your suspension groan, have you visually examined everything ? Try and narrow it down to a specific side if you can, then start looking for anything different from the other side. It may be as simple as a dry bushing or some metal to metal contact where there shouldn't be any. Ask the MFG too, they probably have more insight on their own suspension than anyone.
« Reply #3 on: August 18, 2015, 06:05:59 AM »
You can edit your post and "deselect" the picture you don't want.
Groans on articulation can come from different places - on one of my vehicles it's the rear shocks that "moan" as the fluid flows through the valves
« Reply #4 on: October 11, 2015, 08:22:24 PM »
I had a similar problem.  It was the sway bar link on the passenger side.  The ball and socket joint had come apart.  All of the front end parts are easy to come by and not very expensive.
Offline arced
  • 55
RE: Groan on articulation?
« Reply #5 on: March 16, 2016, 05:01:22 AM »
MESSAGE DELETED
« Last Edit: April 07, 2016, 05:43:46 AM by arced »
Offline arced
  • 55
« Reply #6 on: April 07, 2016, 05:42:00 AM »
Have you called Geoff at Zuki Nation?:
http://www.alteredegomotorsports.com
