TRACKICK GARAGE SALE!
  • 36 Replies
  • 9563 Views
Re: TRACKICK GARAGE SALE!
« Reply #15 on: August 31, 2015, 05:43:26 PM »
more
« Reply #16 on: August 31, 2015, 05:49:03 PM »
more
Offline Thirty-Nine
  • 286
    • Subcompact Culture
« Reply #17 on: September 02, 2015, 03:54:00 PM »
more seat pics, wear on drivers seat, typical from climbing in and out.
Wish you lived closer, darn it. That's a great price.
« Reply #18 on: September 02, 2015, 04:05:10 PM »
Yeah, I hear ya. shipping to Portland would kill it. I may have the engine and all the engine related stuff sold. I'll know for sure on Monday.
« Reply #19 on: September 06, 2015, 11:01:58 AM »
ENGINE, HEADER, INTAKE, COIL AND MAF, ECU, CUBBY ARMREST, SEATS, PULLEYS  SOLD. Still have extended bump stops, new never mounted, used set of Doetsch Tech shocks for a lifted Trackick, complete set of new control arm bushings for both sides F+R NIB, front wheel seal kit, new braced idler arm, trans cooler,electric fans, winch fairlead and cable, 4 2 1 Calmini geared T case with twin sticks, stock t case, Grant wheel and adapter kit, 4 good cleaned 16V injectors, a never installed set of 600 LB Suspension Specialist front Trackick coils. One does have a part of the bottom trimmed off to make a pigtail. A few other odds and ends. ACCEPTING ANY REASONABLE OFFERS. Will try and ship anything than can fit USPS priority for quickest and fastest delivery. 1 WEEK AND IT'S GOING ON EBAY.
Offline DOWNEASTER
  • 104
  • ZUKIWORLD Online!
« Reply #20 on: September 21, 2015, 07:55:26 PM »
hey bud ,you still got that REBUILT 16v 1.6L  ?
« Reply #21 on: September 22, 2015, 06:28:56 PM »
See above. Thanks. EVERYTHING ELSE STILL AVAILABLE. Tcase has been gone through and thrust bearings and main shaft bearings replaced. READY TO INSTALL.
« Last Edit: September 22, 2015, 06:32:04 PM by bentparts »
« Reply #22 on: September 28, 2015, 02:33:41 PM »
Tcase, bump stops, idler arm, wheel seal set, bushing set, steering wheel and adapter, seal savers, window regulator and shocks SOLD!!!
Still have a low milage stock Transfer case, trans cooler, winch fairlead and cable, electric fans 14" and 6", Good, clean engine fan,  and 3 Air Conditioning control modules.
Offline Mccolery5
  • ZUKIWORLD Online!
« Reply #23 on: September 29, 2015, 09:14:42 AM »
Do you have any 95 to 98 soft top trim molding
« Reply #24 on: September 29, 2015, 01:29:27 PM »
Sorry, do not. I had a tintop anyway.
Offline hwyman
  • 175
« Reply #25 on: September 30, 2015, 07:55:28 AM »
do you still ahave the wheelbearing kit and the braced idler arm?
If yes can you give me a price plus shipping to zip code 41144?
Travis
1994 Geo Tracker  2dr 4wd 1.6l 8v Manual Trans
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #26 on: September 30, 2015, 04:15:54 PM »
I have a Superwinch model EPi9.0S - 9,000 lbs/12V winch that has the cable fowled about 50 feet into the spool.  This Superwinch model was discontinued a couple years ago and I can't find any specs on the internet on the actual size of the steel cable that it uses, other than the diameter of the synthetic rope used on the same model was 3/8ths diameter.  Rope is usually a little stronger than similar cable, so I can't just assume 3/8ths steel would work.
I think your wire cable you have for sale would work for my application, but I am not at all positive.  Do you have any experience/knowledge with these Superwinches that could shed light on this?
Thanks,
Norm
« Reply #27 on: September 30, 2015, 04:22:35 PM »
Travis
Hey Travis, Physically, yes but I did take a deposit on a bundle of stuff that included. If that somehow falls through I'll let ya know. Thanks.
« Reply #28 on: September 30, 2015, 04:29:24 PM »
Thanks, Norm.
Hi Norm, unfortunately I have no experience personally with the Superwinch brand of winches other than hearing there  a pretty good value. This was the stock cable and fairlead that came on my Warn, that I replaced with rope for it's lighter weight. I can only tell you it seems pretty stout, was never kinked and has no damage. Hope that helps.
Offline nprecon
  • 2318
  • 52
« Reply #29 on: October 01, 2015, 09:12:08 PM »
Alright, I will attempt to find more detailed tech info on the cable version of this Superwinch beast.  If I find the 3/8ths line works (thickness and connector end) and you still have it available for sale, I will contact you again  and take it off your hands.
Thank you.
Norm
