What did you do to your Sidekick today?
  • 32 Replies
  • 13841 Views
« on: September 20, 2016, 08:38:14 PM »
I have seen similar threads on other forums.  I enjoy reading what other people do to their rides.  I try to do something to my ride each weekend.  It may only be a 15 minute project, but those projects add up over time.
« Last Edit: September 20, 2016, 08:42:24 PM by Ridjobradi »
Re: What did you do to your Sidekick today?
« Reply #1 on: September 20, 2016, 08:40:57 PM »
I pulled out my Lincoln shocks and installed the Deutsche shocks I bought from Boxcar a while back.
Sent from my SM-T330NU using Tapatalk
« Reply #2 on: September 20, 2016, 08:49:02 PM »
I intended to replace all of my sway bar bushings, but the larger bushings that came in were the wrong shape.  I had already pulled the brackets, so I cleaned and painted them.
This was actually from yesterday.  I have several other small projects I will post also
Sent from my SM-G900V using Tapatalk
« Last Edit: September 20, 2016, 08:54:21 PM by Ridjobradi »
Offline fordem
« Reply #3 on: September 21, 2016, 07:39:08 AM »
Take a close look at those bolts - notice the worn threads?  Water gets into the threads from the top and corrodes them - the captive nuts are probably stripped - the easiest way to fix it is to helicoil them.
Offline truesuv
  • 61
  • insert words of wisdom here...
    • Build Diary
« Reply #4 on: September 21, 2016, 01:25:25 PM »
hooked mine up to a battery tender while it just sits there :(
1993 Tracker - Calmini 3" Super articulation and EDSES, plus 3" body lift,  235/85x16 bfg mud terrains, rear locker, header
1987 Samurai Tin top with Calmini 6" suspension, 30" BFG's - sold, I miss it.
« Reply #5 on: September 21, 2016, 10:20:10 PM »
Foredom - Thanks.  I will pull it back out and check them.  It was late and I should have had more light. They have never seize on them now.  I use it a lot.
Offline Thirty-Nine
  • 286
    • Subcompact Culture
« Reply #6 on: October 11, 2016, 07:28:44 AM »
Ordered a new crank bolt so hopefully I can get the Teal Terror running again! Genuine Suzuki part; the Mitsu dealer here still sells 'em.
« Reply #7 on: October 16, 2016, 03:51:36 PM »
Thirty-nine - That's good to hear.  We miss reading about your travels.
Where did "Thirty-nine" come from?
Offline beagle..t
  • 1239
  • 16
« Reply #8 on: October 16, 2016, 07:15:04 PM »
watched it get a rain bath as it sits  :'(
  • 6603
  • 69
« Reply #9 on: October 23, 2016, 07:16:47 PM »
Moved them around.. got one out to prep for the fall classic..
Offline hwyman
  • 175
« Reply #10 on: October 31, 2016, 04:37:44 AM »
This was all done yesterday
Replaced the stock 2dr front disk with rotors, pads and calipers from a 4dr model, I have a soft pedal so I will try bleeding them again this evening when I get home from work
Replaced some of the wires that had shorted out with new wires with the same color and trace on them,  I had temporarily replaced and rerouted the wires when I found the short with solid color wire but wanted to go back to same color codes.  I ordered the wire from 4RCustoms.  I was able to get the same color and trace on the wire in 18ga so I spent sometime yesterday soldering and heat shrinking the wires together.  I am still waiting on one more color to come in and that job should be ready to wrap up.
1994 Geo Tracker  2dr 4wd 1.6l 8v Manual Trans
Offline truesuv
  • 61
    • Build Diary
« Reply #11 on: November 26, 2016, 04:41:45 PM »
Day trip - Borrego / Split Mountain loop - (click on pics to make em bigger!)
drove tracker from Oceanside CA
-- to Borrego
-- toured the metal sculptures
-- to Fonts Point
-- lunch
-- to Ocotillo Wells
-- to Split Mountain
-- up the "Drop Off"
-- checked out the Mud Caves
-- Julian
-- back to Oceanside
Borrego
what the?
Fonts Point
lunch
Ocotillo Wells
Split Mountain
up the "Drop Off"
Mud Caves
 air up... another break... then back to Oceanside via Julian
« Last Edit: November 27, 2016, 08:15:11 PM by truesuv »
« Reply #12 on: November 28, 2016, 06:12:19 AM »
Hwyman - How are the new brakes and wiring repairs?
Trusuv - That looks like a fun trip.  I haven't been out there since '90.  I was in 29 Palms after that.
Offline RSS
« Reply #13 on: November 28, 2016, 08:08:54 PM »
Well where to start? Friday afternoon wife and I headed back home from riding with our 1996 Suzuki sidekick 1.8L 5 speed just as we got to the drive way my Suzuki sidekick started to spit and sputter? Got to the garage and changed plugs and wire boots and still did the same thing. So I got out my OBD2 reader the code came up as 135 and 301 and 330 along with 118 not sure why? So I did a few changes and still the same the thing and now the only thing that comes up is code 301 misfire #1. I happened to start my Suzuki on a cold start and she ran fine until it warmed up on normal temp and then she started to spit and sputter. Why? I changed my coil packs and plugs and O2 sensor and still same thing any idea on what next?
« Reply #14 on: November 29, 2016, 06:48:23 AM »
RSS - Maybe it's the connection from the coil to the plug? When 8t starts to misfire, disconnect one plug at a time to see which one is failing.
