Cross member variations?
  • 2877 Views
« on: August 31, 2017, 04:01:26 PM »
How many different style cross members are there? I think the PO used a 2wd cross member on my new Sport.  The transmission mount from Low Range is different than the one on the vehicle. I am not near my old one to compare the two.
Are there different cross members for 2wd and 4wd?  What about 2dr and 4dr?  Are the sport cross members different than the standard models?
« Last Edit: August 31, 2017, 04:21:20 PM by Ridjobradi »
Offline rasmeidirtrider
  • 76
Re: Cross member variations?
« Reply #1 on: August 31, 2017, 08:25:39 PM »
Hi, I think pic of that would be helpful!
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R/16.
« Reply #2 on: September 02, 2017, 06:16:43 AM »
I have found different styles of cross members, all of which have bent eventually.  Your sport cross member should be different, as the frame is 4" wider (as I have heard).
« Reply #3 on: September 03, 2017, 07:28:46 AM »
I found a rear trans mount on Amazon, that matches the one installed on this Sport. It has 4 bolt holes, two into the cross member and two into the trans. The typical mount has two holes into the cross member and the trans rests on top of it.  It appears to be the same mount used for the Sport and then the Vitara until 2002.
« Reply #4 on: October 28, 2017, 04:14:04 PM »
Here is the rear mount for the Sport.
