Weighed your nodded Suzuki?
  • 2165 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: November 16, 2017, 07:26:07 PM »
What is your suzuki weigh on the scale? Modded sammi, or straight axled trackers I'm interested in, anything on 35 inch tires or above
« Last Edit: November 16, 2017, 07:28:46 PM by bandit86 »
Offline Phase change
  • 199
Re: Weighed your nodded Suzuki?
« Reply #1 on: November 17, 2017, 01:40:43 PM »
cant help specifically but I do know that in larger tires that a light wheel and tire combo can weigh a lot less than a heavy combo in the same size.  I bet 230 lbs could be gained or lost this way in 35's. obviously our rigs don't need or want heavy ones, but sometimes they are the only option.   SAS vs ifs, nit sure if there is much weight difference there.
2003 Suzuki tracker 4d 5sp 2.0 “piglet”
Deleted air 4wd system, Manual hubs, 2” lift, 235/75,
Old ride: 1997 X90 “jellybean” best lil car I’ve ever had
Offline Dat Yooper
« Reply #2 on: November 27, 2017, 08:52:23 AM »
FYI,
I have a 87 Sammy set up for extreme trails, but I run 31x10.50x15's, stock ratio open axles (It's a daily driver on my jobs),
a Lowrange 4.9 transfer case kit, and a modified 1.3 four banger.
I am a insecure farmer, I wear a belt & suspenders, in so, I pack a ton of "If Things Go Too Hell" with us when we go Off Road.
You Just Don't Call the AAA and give them your GPS coordinates  and see how well your Gold Card Membership works out.
With all this gear and my Beer Goiter on board, the Timber Cruiser weighs in at 2,860 lbs, add another 150# if Connie is my Spotter.
