RRO Spacers
  • 23 Replies
  • 6809 Views
Offline ArkansasTracker
  • 85
RRO Spacers
« on: February 21, 2004, 11:29:51 AM »
I installed the RRO spacers today with the help of a friend and I thought I'd share the results.  It took us amateurs about 5 hours to install.  The front was a bugger on the first go around! :-[
Measurements were taken at the same points on each bumper before and after installation.  The truck was also parked in the same location for for each set of measurements.  Front bumper Before: 14.75" / After 17"
Rear bumper Before: 14.25" / After 15.25"
My new set of tires arrived yesterday and will be installed Friday (if I can wait that long).  I'll take additional measurements at that time to see how much lift I gained.
J
'96 Soft Top Geo Tracker, auto (leaking), coil spacers, 30X9.5 Mud Rovers
Offline jagular7
  • 1026
  • Jagular7
Re: RRO Spacers
« Reply #1 on: February 21, 2004, 02:13:16 PM »
Cool. You are going to get an alignment shortly also before installing those new tires?
What's the size you going up to?
Lenexa, KS
  • 85
Re: RRO Spacers
« Reply #2 on: February 21, 2004, 02:29:46 PM »
Yes I am.  Hopefully first thing Monday.  It has a major pull to it!  I also will have to get a set of new shocks very soon.  This thing still has the stockers on it, rusted, rubber dry rotting, etc.  How much do the Rancho 9000's run I've been reading about in here?
I've got the Dunlop Mud Rovers 30 X 9.5 X 15 waiting on me.
Another Question:  will these tires fit, and stay on, a stock wheel?  Or should I break it to the wife that I'll need new wheels as well... :o?  Thanks,
J
Offline Zuki One
  • 441
    • ZUKI - PICS
Re: RRO Spacers
« Reply #3 on: February 22, 2004, 07:24:35 AM »
they will fit but it will be close , but you could still tell her that it would be nice to have some spacers so i dont rub my "NEW" tires when i stuff them and you know how much those tires cost honey im just protecting my investment!Now if you need any mor excuses call me im full of them this is my 4th trail rig and im divorced???i wonder if that has anything to do with each other????hmmmmmmmmmm owell ;D
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
  • 85
Re: RRO Spacers
« Reply #4 on: February 22, 2004, 08:20:46 AM »
I checked the measurements against the 235s and the 30s are only .25" wider.  I guess we'll know for sure very soon.
The other thing is I don't think the new matching spare will fit on the stock mount. :o  Any ideas/suggestions are appreciated.
Thanks for the excuses Bug...I think. ;D  The wife is pretty sharp.  She already questioned getting coil spacers and tires BEFORE fixing the tranny (if it goes its a must fix 8)).
J
Offline mahimahimo
  • 377
Re: RRO Spacers
« Reply #5 on: February 22, 2004, 08:58:59 AM »
what type of spacers are did u put in? im looken to throw sum spacers in to im not to sure what is the best ones to go with
Offline jagular7
  • 1026
  • Jagular7
Re: RRO Spacers
« Reply #6 on: February 23, 2004, 12:38:54 AM »
....snip.... The other thing is I don't think the new matching spare will fit on the stock mount. :o  Any ideas/suggestions are appreciated.
Take a look at some of the Jeep spare tire relocators or some name like that. Basically what it is, it bolts onto the 5on5.5" bolt pattern (which you have), and extends the mounting up and out some 2".  These bolt directly onto the stock mount. The mount now for the tire is higher and out. I'll see if I can find something what I'm talking about.
Lenexa, KS
Offline jagular7
  • 1026
  • Jagular7
Re: RRO Spacers
« Reply #7 on: February 23, 2004, 12:44:24 AM »
Here is a link from JC Whitney for a WP Warrior rear tire spacer http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?makeId=8000123&productId=6567&catalogId=10108&langId=-1&storeId=10101
Lenexa, KS
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: RRO Spacers
« Reply #8 on: February 23, 2004, 09:27:59 AM »
The only problem with that is that it puts extra stress on your back door.  I cut out a section of the rear bumper so that the spare will fit.
So far (nock of wood) it hasn't stressed out the door and ripped the sheet metel.
32 MTR's Warn 8000i
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: RRO Spacers
« Reply #9 on: February 23, 2004, 11:13:13 AM »
Thats why Im running theCalmini rear bumper/ tire carrier! My fricken tire tore my back door in half!  ::)
Mike
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: RRO Spacers
« Reply #10 on: February 23, 2004, 11:15:01 AM »
Mike
I also have one of those on order also.   ;D
Anyone in Michigan want my rear bumper when I get my new one??
32 MTR's Warn 8000i
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: RRO Spacers
« Reply #11 on: February 23, 2004, 11:27:18 AM »
Cool. You'll like it. That thing is so fricken tough. I was actually kinda suprised to see how its not nearly as heavy as I thought it would be.
Mike
  • 85
Re: RRO Spacers
« Reply #12 on: February 24, 2004, 02:14:38 PM »
mahima,
I went with the Rocky Road Outfitters 1" (may have been 1 1/8") spacers.  The back two were fairly easy.  The fronts were a bear!  The cost was about $90 for the set of 4.
As for the new tires...SWEET!  Man, they look really good.  They fit, but rub pretty good during sharp turns.  My rig was a tow vehicle for the past owner and it still has the front tow bars mounted.  The tires hit these pretty good so I may have to take them off.  I really hate to though cause they've saved my plastic bumper a time or two.
I've got an alignment scheduled for Thursday and then we'll try these new treads in the mud.  In about two weeks I'll be at the ORV park in hot springs.  They'll get a real good test there!
As for "lift" on the vehicle so far...the back started at 14.25" and is up to 16.75."  The front started at 14.75" and is up to 18.5" now.  It has a real nice stance now especially with the aggressive tires (working on some pics).  I'll measure true ground clearance this weekend.
Thanks for the spare tire ideas.  I'll let you know what I decide on.  Thanks guys.
J
Offline mahimahimo
  • 377
Re: RRO Spacers
« Reply #13 on: February 25, 2004, 11:48:45 AM »
aright thanx....i def gotta order a pair my tires but pretty nicely especially when there 3 or 4 people in my track......how long did they take to come? also i found a pair of coil spacers that lift 1 1/2 inches heres teh link ftp://http://www.sky-manufacturing.com/ any one know which is better?
  • 85
Re: RRO Spacers
« Reply #14 on: February 25, 2004, 02:05:31 PM »
I ordered my Dunlop Mud Rovers from Sam's Club and they were in the store in about 7 days.  We'll see how they hold up...
I think I'll try to fab up something for now to hold the spare.  I'd like a winch bumper for the front and the calmini rear sounds like the way to go.  Now to fund the project :-/
Of course I'll need the suspension lift to support all that extra weight as well... ;D
J
