Jumped Timing/Bent Valve
  • 10 Replies
  • 3063 Views
« on: January 23, 2004, 02:40:20 AM »
Dont Panic, it was not a Zuk ;)
A friends Kia Jumped timing and bent a valve. What other dammage could this of done to her motor? The mechanic the F'ed up the timing belt is going to fix it but can this cause other problems dow the road?
Re: Jumped Timing/Bent Valve
« Reply #1 on: January 23, 2004, 02:55:05 AM »
The only other thing I can think of is
a hole in the piston, but that is when
the top of the valve pops off and trashes
the head too.
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #2 on: January 23, 2004, 04:59:02 AM »
have the rod checked too.  I've seen a piston stay intact on like this but the rod is ever so slightly bent.
And yes, thank the gods of hamamatsu it was NOT a zuke!
« Last Edit: January 23, 2004, 04:59:28 AM by samurai_hamster »
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: January 24, 2004, 03:38:53 PM »
I have a phobia of Timing Belts....  :(
I watched my mechanic very carefully when he replaced mine a few months back.  I was pretty freaked out.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #4 on: January 25, 2004, 12:30:51 PM »
He Let You Watch! That is usually double labor costs for an audiance! ;)
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: January 25, 2004, 12:54:00 PM »
It can do any and all of bent rods, crapped heads and holes in pistons.  HOWEVER some engines were designed with this problem in mind, and have the valve recesses cut in the piston, with sufficient clearance.  My mazda was the same way, I started jumping teeth on the right side because of a faulty tensioner and the engine ran on the left bank while the right bank's cam just did it's thing.   New tensioner, idler pulleys and belt and the car ran great.
« Reply #6 on: January 25, 2004, 09:38:14 PM »
Thanks, the mechanic tore the motor down this weekend and we should find out something by the middle of the week.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: January 26, 2004, 08:14:01 AM »
why not just get another one from the wreckers? probably a better way of doing it, you dont want a stress crack to haunt you
« Reply #8 on: January 26, 2004, 10:32:01 PM »
The Mechanic screwed it up and he his fixing it. He is a reputable mechanic that hired a slacker, and I'm sure that he will fix it right. If ti would of been cheaper to just buy another motor from the junk yard, I'm sure he would of done it.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #9 on: January 27, 2004, 10:52:13 AM »
No way dude!  :)  My mechanic is ultra cool, I'm often right beside him when he does work.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #10 on: January 27, 2004, 12:50:22 PM »
MY MECHANIS ALLOWS ME HANDS ON HELPING OUT...LEARNING SLOWLY... HE EVEN LET MY 8 YEAR OLD SON HELP WHEN WE WERE PUTTING IN THE LIFT...... ;D
