4 door Kick brakes on a 2 door Kick?
  • 28 Replies
  • 6384 Views
Offline ksa421
  • 382
« on: January 26, 2004, 09:38:25 AM »
Does anyone know if the brakes off of a 4 door Kick will fit on a 2 door kick? Will the just bolt right on? ??? Thanks
Jacob
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 4 door Kick brakes on a 2 door Kick?
« Reply #1 on: January 26, 2004, 11:28:03 AM »
It's supost to be an easy swap.  I guess a lot of people will take the front rotor and use it on the rear and then get 4 door rotors and calipers and just bolt them on.
I'm trying it this spring.
32 MTR's Warn 8000i
« Reply #2 on: January 26, 2004, 11:36:23 AM »
I think what he was asking is will the fronts fit the front and will  the rears fit the rear kinda thing 8) he found a 4 door parts rig.
Offline ksa421
  • 382
« Reply #3 on: January 26, 2004, 11:46:36 AM »
Yep thats what I was askin, but i am kinda intriuged with the discs in the rear idea too. anyone have any more info?
Jacob
« Reply #4 on: January 26, 2004, 12:02:10 PM »
Do it !! You will not be disappointed.
Grab all the parts
backing plate
rotor
caliper
bracket caliper bolts to
pads
hoses for spares
I only did the front, rear is stock 2 door
Great mod, Do it  ;D
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: January 26, 2004, 01:28:42 PM »
Its as easy as you would think. Do it. I love it. I have front 4 doors calipers and rotors on mine. I had rears also until I did the rear disc swap.
Mike
« Reply #6 on: January 26, 2004, 10:58:29 PM »
Hey if the 4 door has bigger brakes does it also have an uprated mastercylinder?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #7 on: January 27, 2004, 12:41:03 AM »
No. The pistion and wheel cylinders are still the same volume. Just the discs and drums got larger.
Mike
« Reply #8 on: January 27, 2004, 01:55:07 AM »
I beg to differ  :o , the piston in the caliper
appears to be larger, at least from the outside,
than the 2 door caliper, I didn't take mine apart
as they worked fine so I'm not 100% on this.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #9 on: January 27, 2004, 02:01:25 AM »
I didnt measure the two but I remember thinking that they looked like they were the same size. I am 100% positive that the wheel cylinders are the same though.
Mike
« Reply #10 on: January 27, 2004, 02:07:32 AM »
So to do the backs you just get the shoes
and drums/hardware and enjoy
I remember them looking the same until I
put them next to each other, the 4 door looks
like the 2 door on steroids  ;D  similar in
appearance but larger over all
« Last Edit: January 27, 2004, 02:09:49 AM by wildgoody »
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #11 on: January 27, 2004, 02:15:08 AM »
Nope, when I did the swap I accidentaly pumped the break pedal without the rr drum on and blew the cylinder. :-[ I used the cylinder from my 2 door backing plate cause it was laying there. It was definately the same.
Mike
« Reply #12 on: January 27, 2004, 02:20:16 AM »
I was referring to the front Caliper,
I never changed the backs, Sorry
I was not clear in the previous post.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #13 on: January 27, 2004, 02:22:19 AM »
Id go check but my rig is in the paint booth today.
Mike
« Last Edit: January 27, 2004, 02:22:57 AM by Mikerpm4x4 »
« Reply #14 on: January 27, 2004, 02:25:01 AM »
It's Not Done Yet !!!!   :(
Are you going through withdrawals
or are you over the hump yet  ???
