4 door Kick brakes on a 2 door Kick?
  • 28 Replies
  • 6437 Views
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: 4 door Kick brakes on a 2 door Kick?
« Reply #15 on: January 27, 2004, 02:34:37 AM »
Withdrawls... WITHDRAWLS!!  :o Im going ffin insane! Hopefully I will get it back tomorrow. Then I have to figure out where all there little pieces go.  :o  Latches, rods, windows, handles, and oh dear. There is so much stuff.  Just think how simple these rigs are and they still have so much stuff. I couldnt imagine doing this to something like a cadilac.
Mike
« Reply #16 on: January 27, 2004, 02:41:15 AM »
I'm happy and sad for you,
Happy the Trucklet was prepped
right, and you'll have none of that crappy
overspray on the trim and latches and stuff.
And I'm sad to hear your 21 Day program isn't
working, hasn't it been about 21 days since she's
been gone ??  and your still suffering.
I'm sorry to say I think you are a hopless zukaholic,
and there is no cure for you, your stuck with the rest
of us, so you'll just have to put up with us and this
board for the rest of your life.
(like that's a bad thing  ;D )
« Last Edit: January 27, 2004, 02:42:47 AM by wildgoody »
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #17 on: January 27, 2004, 02:47:41 AM »
Wow, 21 days..... seems like a lot longer.  :-[ I guess Ill quit whinning.
Mike
« Reply #18 on: January 27, 2004, 02:49:35 AM »
Hey Mile, I drove my Kick yesterday :P Did you ::) The sound of air flowing into the soft top, MT's humming down the road, the sharp bounce as the rear end hits a pot hole ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #19 on: January 27, 2004, 02:52:45 AM »
 >:( You are a bad bad man! >:(
Paybacks are a bitch.  ;)
Mike
« Reply #20 on: January 27, 2004, 02:56:46 AM »
Allright Zig, it's not nice to tease Mike,
he's going through a hard time.
Zig, Go To Your Room !!
Time Out for 10 Min.
Offline ksa421
  • 382
« Reply #21 on: January 27, 2004, 03:12:47 AM »
So when i do this I am gonna lose some brake fluid right? How much brake fluid does it take for the whole system? Thanks for the info :D
Jacob
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
« Reply #22 on: January 27, 2004, 03:19:36 AM »
Get a quart and bleed all the old
stuff out from all the lines and cylinders.
DOT 3 or 4  don't get 5 as it's not compatable
with regular fluid without a complete flush of
all the old fluid from the system.
« Reply #23 on: January 27, 2004, 03:24:22 AM »
KSA,
If you have your new stuff there when you remove the old you can do it without loosing much. Just unscrew one break from the line at a time and replace it with the new. After bleeding the breaks good, you will be good to go ;D
Wild,
See, I waited 10 minutes :P
Mike, ;D I could not help myself :P Give us some pics when you ger her back.
Offline ksa421
  • 382
« Reply #24 on: January 27, 2004, 03:25:11 AM »
I was haven some probs with the brake not too long ago(glazed over the rear shoes) and I had them bled about a month ago. Do I still want to put fresh stuff in?
Jacob
« Reply #25 on: January 27, 2004, 03:25:53 AM »
I know this may be a dumb question. Brake Fluid need to be changed ???
Offline ksa421
  • 382
« Reply #26 on: January 27, 2004, 03:28:16 AM »
I heard after a while it can get a little water in it and makes it not so good. Sorry I dont remeber the details of it.
Jacob
Offline Cowtracker
  • 39
  • I love YaBB 1G - SP1!
« Reply #27 on: January 27, 2004, 04:45:07 AM »
brake fluid does absorb water and in cast iron housings that's not good this is basicly what leads to stuck caliper and wheels cyls
For thisd reason
some european makers actualy have you change the brake fluid as scheduled maintence.
BTW dot 5 fluid is silicone based and will not absorb water but it's not compatible with dot 3or 4 and is expencive.
Dot 3 is the basic brake fluid.   Dot 4 is an upgrade with a higher boiling point AND it doesn't absorb water as well as dot 3
I use dot 4 in all my stuf cuz i like upgrades but I am not made of $$$$$4
Guitars,zukes and hilbilly music!
« Reply #28 on: January 27, 2004, 07:12:25 AM »
Wild,
Ya, I know, I got lonely with nobody to talk with  :'(
Can Zig come out and Play ??   Please  :-*
