ZUKES FEELING BETTER !
  • 3159 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« on: January 16, 2004, 01:45:27 PM »
ZUKES FEELING BETTER ...HAD SOME WATER IN THE GAS TYPE BLUES ..ADDED DRY GAS AND CHANGED THE FUEL FILTER AND SHE WAS RUNNING GOOD AGAIN....OR ATLEAST I THOUGHT....MY NEIGHBOR WHO'S A MECHANIC WAS HELPING ME..ONCE WE GOT RUNNING AGAIN HE SAYS SOUNDS AS IF YOUR RUNNING ON THREE CYLINDERS...HMMM. SOUNDED AS NORMAL TO ME..AWW BUT WHAT DO I KNOW, I'M JUST A BOX CARRIER  ;) SO HE PULLS PLUG WIRES FRONT TO BACK...1ST 3 MAKES ENGINE STUMBLE LAST ONE PRETTY MUCH NO CHANGE WHEN PULLED...I THINK WOW HE'S RIGHT WHAT AN EAR..CAUSE IT SURE RAN FINE PLENTY OF POWER  :-[ SO I RUN AND GET NEW WIRES AND PLUGS...PULL OUT THE PLUGS WHAT DO YOU KNOW SOME MORON PUT CHEVY AC DELCO PLUGS IN IT.....ALL GAPPED 3 TIMES WHAT THEY OUTTA BE....SO HE GETS THEM ALL IN AND WALLA...PURRING LIKE A KITTEN, A LITTLE MORE POWER THEN ITS EVER HAD...AND I GOT TO TURN THE IDLE BACK DOWN ( TURNED IT UP CAUSE IT KEPT IDLING DOWN ABOUT 400 AT STOP LIGHTS) ....NOW SHE SITS AT ABOUT 950/1000 RPM'S AT IDLE ALL THE TIME....ITS TOUGH BEING MECHANICLLY CHALLENGED BUT I ALLWAYS SEEM TO FIND THE HELP I NEED  ;)  NOW I GOTTA CHANGE THE FRONT BRAKE PADS......
Re: ZUKES FEELING BETTER !
« Reply #1 on: January 16, 2004, 02:54:48 PM »
How did ya turn the idle down ??? Don't ya have a 16 valve?
  • 2274
« Reply #2 on: January 16, 2004, 10:55:41 PM »
YES IT IS..... HEATHER YOU HAVE A PICTURE OF THE LOCATION....COLD YOU POST IT AGAIN.... ITS RIGHT ON  TOP OF MOTOR MORE TOWARDS THE LEFT AND BACK ...HAS OR MAY NOT HAVE A LITTLE RUBBER PLUG COVERING IT...TURN SLOWLY TIL YOU GET YOUR IDLE WHERE YOU WANT IT....STAND ON THE THROTTLE A BIT ...THEN LET IDLE DOWN TO SEE HOW IT STAYS...
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: January 17, 2004, 04:28:33 PM »
Yep.. here you go:
Heather
Heather Galvin
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #4 on: January 17, 2004, 04:48:28 PM »
That's what mine is going to sound and feel like as soon as I get a new muffler!!!  ;D
  • 2274
« Reply #5 on: January 20, 2004, 12:47:44 PM »
THANKS HEATHER
