N O S for mud or sand dunes
  • 2333 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: January 17, 2004, 01:34:11 PM »
I have been thinking about A small sys. to use when needed line A large dune the dunes in southern Ca. are big and long. And dry or wet kit?
Re: N O S for mud or sand dunes
« Reply #1 on: January 17, 2004, 01:37:47 PM »
I prefer my Turbo  ;D
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #2 on: January 17, 2004, 01:40:49 PM »
What is your rig?
Tracker/Kick go with a wet kit. I always felt these were safer than a dry kit. Nitrous Express sells an import kit with a single nozzle,made for the import cars,that is a complete kit. It has wiring, arming switch, and a microswitch that comes with the kit.
You can run 35hp setting with no timing or sparkplug changes.
If you need more info or help PM me. Ive ran NOS on cars for years.
Later,
Bill
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: January 17, 2004, 01:43:27 PM »
Do you ever go to imperial dunes aka glamis? and can you make it up oldsmobile, I can run all the dunes but when I have to slow down cause the serious whoops I cant get enough momentum. :-/
