Please help!
  • 31 Replies
  • 9191 Views
Offline Speedracer7c
  • 2210
Please help!
« on: January 03, 2004, 12:52:48 PM »
I desperatly need some 5.13 ring and pinons front and rear!!! If anyone has them please let me know!!
Offline 1bigtracker
  • 3409
Re: Please help!
« Reply #1 on: January 03, 2004, 02:18:57 PM »
try hawk
  • 2210
Re: Please help!
« Reply #2 on: January 03, 2004, 04:38:12 PM »
Already did, said they only sell as part of their hybrid axel setup.....I want to get my lift and stuff started but there is no point if i can't find any gears.  :-/
Offline track_this
  • 332
Re: Please help!
« Reply #3 on: January 03, 2004, 04:47:11 PM »
On ebay there is people that will say "parting out..." i would see if they can source soem gears for ya, i know i had a guy lined up to sell me the front 5.13 gears once but found em' cheaper, just use the ask seller a question link.       shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
  • 2210
Re: Please help!
« Reply #4 on: January 03, 2004, 04:53:46 PM »
Thanks, good idea. At least i'm not the only die hard online at 2 in the morning!!!
Re: Please help!
« Reply #5 on: January 03, 2004, 05:51:36 PM »
Is your Tracker an Auto ???  If not you allready have 5.12 gears.
Offline 1bigtracker
  • 3409
Re: Please help!
« Reply #6 on: January 04, 2004, 02:00:40 AM »
hey i have been online for the last two weeks till like 2 or 3 in the morn.  just last night was sleep catch up.  lata stu
  • 2210
Re: Please help!
« Reply #7 on: January 04, 2004, 02:00:21 PM »
Yup it sure is the infamous 3 speed auto....blah....I need them before I will even think of putting bigger tires on.
Offline bandit86
  • 1641
  • elv8rguy
Re: Please help!
« Reply #8 on: January 04, 2004, 02:02:36 PM »
my buddys auto did burnout with 32s.  I'd go with the lift/bigger tires first, you can always worry about it if you need it.  Most times I use 4low for offoading anyways, so Tou already have low gears.
  • 2210
Re: Please help!
« Reply #9 on: January 04, 2004, 02:06:24 PM »
Hmm....I dunno about that. I got the 16 valve motor, and When its stuck with the stock tires it wont even sping them in 4 low in the mud...maybe there is something else wrong with it.  Andrew
Re: Please help!
« Reply #10 on: January 04, 2004, 02:23:05 PM »
What are you calling bigger tires???
I run 33s on stock gears, ya you feel
it, if you want to go to 31s and use 5.12/5.13s
this will be close to stock on 205-75 15s
You got some $$ I can check to see if the
Track/Kick is still there, I want some parts
too so I need to go before they crush the
Trucklet, one is a Man trans, the other is auto.
some bonehead pulled the valve body off
the auto I wanted for a spare  >:(
Lemme Know
Darrin
Offline bandit86
  • 1641
  • elv8rguy
Re: Please help!
« Reply #11 on: January 04, 2004, 02:26:10 PM »
go for 32s at least, maybe 31s, you can do that cheaply with a 3 inch body lift.  Try to find 12.5 wide tires, helps you roll over stuff rather then sink in it.
  • 2210
Re: Please help!
« Reply #12 on: January 04, 2004, 02:26:22 PM »
That is precisely my plan, the 5.13's with a 31 or so. Do you run the 3 speed in your zuk? Its amazing the places I have taken my tracker stock so I can only imagine how much better it is with more ground clearance. Also yeah I have money, how much do you think the gears would be. Thanks Andrew
  • 2210
Re: Please help!
« Reply #13 on: January 04, 2004, 02:27:53 PM »
I was looking at the bds coil lift. My friend owns a shop that sells them I dunno how it will stack up to a calmini but It it will do the job rather well I think if I put the RRO 2 inch body lift in too. I would love to go with a 12.50 wide tire, but in New Hampshire where I live, you have to pass the quarter test where they put a quarter flat on the farthest point out  and drop it, if it hits your tire you get wacked with a 63 dollar fine and if they catch you again the impound the car until you get flairs on it. Andrew
« Last Edit: January 04, 2004, 02:29:48 PM by Speedracer7c »
Offline bandit86
  • 1641
  • elv8rguy
Re: Please help!
« Reply #14 on: January 04, 2004, 02:34:36 PM »
I made a chep set of yj fenders work on mine, rear is switched side to side, front is cut into 3 sections, shortened at top where turnsignal was and extended down by rocker.  will post pics tomorrow.
