Struts
  • 16 Replies
  • 4961 Views
Struts
« on: October 08, 2003, 10:28:58 PM »
Who has the best (most durable) struts for a Kick ??? I have blown out another strut and need to purchaes a set.
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
Re: Struts
« Reply #1 on: October 09, 2003, 02:12:01 AM »
Old man emu struts!
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline Z3bra
  • 273
Re: Struts
« Reply #2 on: October 09, 2003, 02:39:35 AM »
Can't speak from personal experience as far as their reliability on a track/kick, but I believe Deutsch Tech makes a set.
Offline safarikick
  • 270
  • nor-cal rhinos
Re: Struts
« Reply #3 on: October 09, 2003, 05:59:30 PM »
« Last Edit: October 09, 2003, 06:06:08 PM by safarikick »
Offline okezuki
  • 51
Re: Struts
« Reply #4 on: October 16, 2003, 07:17:14 AM »
BDS SUSPENSION! ;D
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Offline hcgalvin
  • 1695
    • Granite Path
Re: Struts
« Reply #5 on: October 16, 2003, 09:25:42 AM »
Does BDS make like a 2" lifted strut? I could probably get them locally... I need struts too (mine are blown).
Heather
Heather Galvin
Offline safarikick
  • 270
  • nor-cal rhinos
Re: Struts
« Reply #6 on: October 16, 2003, 03:41:56 PM »
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
bds-suspension.com/pdfs/suzuki.pdf
« Last Edit: October 17, 2003, 02:40:04 AM by ebewley »
Offline track_this
  • 332
Re: Struts
« Reply #7 on: October 16, 2003, 07:45:02 PM »
on the struts, there is no spacer it is actually 2" longer than stock??
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline okezuki
  • 51
Re: Struts
« Reply #8 on: October 17, 2003, 03:56:07 AM »
Yes , the struts are longer. :)
Re: Struts
« Reply #9 on: October 19, 2003, 11:52:38 PM »
Thanks! I'll check them out. I do need the stock length, or a 3" longer than stock (then I could eliminate my strut drop)
Re: Struts
« Reply #10 on: October 19, 2003, 11:57:52 PM »
3" strut drop seems a bit excessive, do you still have the stock bumpstops. I would have thought that you would top out the strut, maybe thats why you are blowing them so often.
Re: Struts
« Reply #11 on: October 20, 2003, 02:38:13 AM »
I'll check and see if they are. I'm not sure if it is 3", but it's the drop bracket that comes with the Calmini 3" Kit.
Offline UberAsuna
  • 239
  • Asuna Sunrunner 92'
    • Cranky's Ghetto My Website
Re: Struts
« Reply #12 on: October 20, 2003, 02:16:52 PM »
about those DBS struts ...
Lets say i put back my 2" coil spacers in the front and use those struts all my adjusting camber nightmare will be gone ? or will i still have to play around everything in the front to make the tires be straight insted of being " / \ "   <-- like that ...
It's A Zuki Thing, Dig It Sucka ;) :D ;D
Re: Struts
« Reply #13 on: October 20, 2003, 03:05:17 PM »
My 3" suspension lift made the tires go \  /
so I made a set of extensions that fit
the top of the strut mount and move the
struts inward so now the tires are pretty
much straight, just some eyeball
engineering ;)
Offline Natebert
  • 1098
Re: Struts
« Reply #14 on: October 20, 2003, 04:07:57 PM »
just some eyeball
engineering ;)
Sounds TOO familiar sometimes!
