Struts
Struts
25
Struts
October 08, 2003, 10:28:58 PM »
Who has the best (most durable) struts for a Kick
I have blown out another strut and need to purchaes a set.
Fredo
416
Heavy music and Suzuki 4x4!
Re: Struts
October 09, 2003, 02:12:01 AM »
Old man emu struts!
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Z3bra
273
Re: Struts
October 09, 2003, 02:39:35 AM »
Can't speak from personal experience as far as their reliability on a track/kick, but I believe Deutsch Tech makes a set.
safarikick
270
nor-cal rhinos
Re: Struts
Reply #3 on:
October 09, 2003, 05:59:30 PM »
http://www.puresuzuki.com/sidekick_tracker.htm
Last Edit: October 09, 2003, 06:06:08 PM by safarikick
3+3 calmini 5.12 a lock in the back and front with steel front diff. 4.24 in tc
okezuki
51
Re: Struts
Reply #4 on:
October 16, 2003, 07:17:14 AM »
BDS SUSPENSION!
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
hcgalvin
1695
Roads? Where we're going, we don't need roads.
Re: Struts
Reply #5 on:
October 16, 2003, 09:25:42 AM »
Does BDS make like a 2" lifted strut? I could probably get them locally... I need struts too (mine are blown).
Heather
Heather Galvin
safarikick
270
nor-cal rhinos
Re: Struts
Reply #6 on:
October 16, 2003, 03:41:56 PM »
bds-suspension.com/pdfs/suzuki.pdf
Last Edit: October 17, 2003, 02:40:04 AM by ebewley
track_this
332
Live for something or die for nothing
Re: Struts
Reply #7 on:
October 16, 2003, 07:45:02 PM »
on the struts, there is no spacer it is actually 2" longer than stock??
1994 geo tracker 1.6L 16v 4x4 2dr soft top 5.12 gears.MODS:
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
RRO 2" body lift custom snorkel front & rear trail tough bumpers-Tabor 9k winch(warn) 100amp alt. grand vitara steel 3rd member
okezuki
51
Re: Struts
Reply #8 on:
October 17, 2003, 03:56:07 AM »
Yes , the struts are longer.
25
Re: Struts
Reply #9 on:
October 19, 2003, 11:52:38 PM »
Thanks! I'll check them out. I do need the stock length, or a 3" longer than stock (then I could eliminate my strut drop)
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: Struts
Reply #10 on:
October 19, 2003, 11:57:52 PM »
3" strut drop seems a bit excessive, do you still have the stock bumpstops. I would have thought that you would top out the strut, maybe thats why you are blowing them so often.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
25
Re: Struts
Reply #11 on:
October 20, 2003, 02:38:13 AM »
I'll check and see if they are. I'm not sure if it is 3", but it's the drop bracket that comes with the Calmini 3" Kit.
UberAsuna
239
Asuna Sunrunner 92'
Re: Struts
Reply #12 on:
October 20, 2003, 02:16:52 PM »
about those DBS struts ...
Lets say i put back my 2" coil spacers in the front and use those struts all my adjusting camber nightmare will be gone ? or will i still have to play around everything in the front to make the tires be straight insted of being " / \ " <-- like that ...
It's A Zuki Thing, Dig It Sucka
wildgoody
8134
67
Turbocharged 150HP 1.6L 8V 93MPH 1/4 mile
Re: Struts
Reply #13 on:
October 20, 2003, 03:05:17 PM »
My 3" suspension lift made the tires go \ /
so I made a set of extensions that fit
the top of the strut mount and move the
struts inward so now the tires are pretty
much straight, just some eyeball
engineering
Natebert
1098
Re: Struts
Reply #14 on:
October 20, 2003, 04:07:57 PM »
just some eyeball
engineering
Sounds TOO familiar sometimes!
