Bumper pretty much finished...
  • 3948 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: September 01, 2003, 01:35:53 PM »
Just have to add on the Jerry Can mounts, and a stopper for the arm to keep it from swinging all the way around when it is open. Also needs another coat of paint...
Whatchoo think so far?
Check out more here:
http://www.whitepineclub.com/members/kd7hcg/pictures/rearbumper3/index.html
Heather
Heather Galvin
Re: Bumper pretty much finished...
« Reply #1 on: September 01, 2003, 04:44:54 PM »
Heaven help anyone that runs into the back of you.
First look I thought it was too low, but as I see it
in some of the othere pics it will be OK, watch your
knees around that thing tho, take your caps right off.
I saw a 2 door hardtop, a Nissan quest rearended the guy,
totally destroyed the Quest, bent the bumper down on the
zook, I would say this bumper is a bit more stout than the
stocker, looks bullet proof !!
Good Job ;)
Darrin
jdraper
« Reply #2 on: September 01, 2003, 11:32:47 PM »
Looks pretty good.  I built a similar square tube bumper for the back of my Sammy, but I don't have the tire swingout on it.....yet.  What did you use for a pivot point?  I didn't see any pix of it on your website.  Did you put a bronze bushing or a bearing in for it to turn on??
 BTW, here's a shot of mine...
« Last Edit: September 01, 2003, 11:34:39 PM by jdraper »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: September 02, 2003, 02:26:33 AM »
You can see the hinge point here: http://www.whitepineclub.com/members/kd7hcg/pictures/rearbumper2/index.html
We used a hub and spindle from a trailer. This includes the bearings and the grease. The original hub with the flange that had the four bolts was cast and you couldn't weld to it, so we hade a tube machined with the same dimensions minus the flange. The new tube got the races and the bearings too.
It works really well.
We still are going to cap the ends off the bumper so it will look cleaner.
Heather
Heather Galvin
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #4 on: September 02, 2003, 10:20:58 AM »
LOOKS GOOD! IF I ONLY HAD ONE :'(  ALL IN GOOD TIME...ROME WASN'T BUILT IN A DAY  ;D   MATTY D..
  • 2274
« Reply #5 on: September 02, 2003, 11:24:31 AM »
JUST WENT TO YOUR SIGHT AND CHECKED OUT THE  FULL INDEX OF PICTURES...LOOKS SWEET... NOW IF YOU COULD JUST DO A WRITE UP ON FULL DIMENSIONS  :-* MAYBE IT WOULD MAKE IT EASIER FOR ME TO GET MY FRIEND TO BUILD SIMILAR THING FOR MYSELF ::)  MATTY D.       8)
Offline W7ACT
  • 30
« Reply #6 on: September 04, 2003, 08:02:16 AM »
Nice License Plate! ! ! !
OH, Yes the bumper looks good too.
