Woohoo.. we did it! Gas tank is higher!
  • 3894 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: August 22, 2003, 09:15:15 AM »
Well... we still need to attach a skid plate, but, the gas tank is about 4 inches higher. See my page! Also, those of you just starting out with a custom body lift, or a lift that uses the stock body bolts should look at this too.
http://www.whitepineclub.com/members/kd7hcg/pictures/gastank/index.html
Heather Galvin
Offline brace
  • 264
  • I built it; I break it; I fix it.
Re: Woohoo.. we did it! Gas tank is higher!
« Reply #1 on: August 22, 2003, 11:24:26 AM »
Great job and pics; really informative.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #2 on: August 22, 2003, 02:58:44 PM »
LOOKS GOOD  :o  KEEP UP THE GREAT UPDATES ON YOUR KICK :P HAPPY ZUKING!  ;D MATTY D.  8)
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #3 on: August 22, 2003, 07:28:19 PM »
Time to get that rig airborn! ;D
jookycola
« Reply #4 on: August 24, 2003, 03:24:58 PM »
What's this "flipping (inverting) the front strut mounts" deal?  You've piqued my interest on this mod but am curious what the task entails?
welding?
or just mounting the strut differently?
Offline Natebert
  • 1098
« Reply #5 on: August 25, 2003, 03:56:53 AM »
welding?
no welding, just mount the strut differently on top.
Here are some super simple instructions.
0) use some commen sense, be safe and think about what you are doing.
1) Jack up front of truck, set frame on jack stands.
2) remove tires to make it easier on yourself.
3) Use jack under A-arm to relieve pressure on strut  and keep spring from 'blowing out'.
4) unbolt upper strut nut.  (under hood)
5) unbolt 3 bolts that hold the upper strut ring.  (under hood/in fender)
6) flip strut mounting ring over, mount under fender.  (use washers to keep bolts from tearing out on top and to act as spacers between the beveled edge of the frame and the strut mount, underneath)
7) bolt everything back together.
You should now have ~1 inch of extra down travel and about 1 inch less up travel.
This mod is good to do in conjunction with .75 inch spring spacers up front.  (to keep the strut centered.)
Some photos of the finished installation can be seen here.
http://www.whitepineclub.com/members/kd7hcg/pictures/tjspacers/index.html
« Last Edit: August 25, 2003, 04:14:37 AM by natebert »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #6 on: August 25, 2003, 06:43:22 AM »
Look at all that clearance! (Yeah... I cleaned my rear axle.. all nice and shiny now. I should write something on the pumpkin.. LOL)
Here's another update BTW!
http://www.whitepineclub.com/members/kd7hcg/pictures/rearbumper2/index.html
Heather
« Last Edit: August 25, 2003, 06:44:40 AM by hcgalvin »
Heather Galvin
Offline MEDEL514
  • 52
  • Ramstein, Germany
« Reply #7 on: August 26, 2003, 04:20:53 PM »
Thats a huge rear bumper!!!  I like the idea of flipping the strut ring underneath.  I just put the spring spacers in and went for a run in the dirt.  I noticed a little bang or thump when the front would catch a little air.
Thats probably the strut topping out?  I'm gonna flip the ring and remove the front bump stops to see if that helps a bit for flexing.
90' Tracker
- with some goodies
