Rear Rotated Calmini upper link Question
  • 2418 Views
Offline kozaz
  • 168
« on: April 28, 2005, 08:40:51 AM »
I was reading the mod by Mike H, and was wondering why the upper link was not set up by Calmini to correct rear pinion angle in the first place?   ???
Is there a reason why they built it that way?
Offline 1bigtracker
  • 3409
Re: Rear Rotated Calmini upper link Question
« Reply #1 on: April 28, 2005, 08:42:32 AM »
i think it might have somthing to do with having to remove the rear coil cups and move them on the axle also.
stu
« Reply #2 on: April 28, 2005, 01:43:14 PM »
The Calmini Upper V bar with the adjustment allows the owner to adjust the suspension to their best possible results without cuting off and relocating the cups. The average Joe wants a good performing Bolt On Kit and that is what Calmini produced. I was more than pleased with my Kit as sold by calmini but like it even better after over-rotating it ;)
Offline kozaz
  • 168
« Reply #3 on: April 29, 2005, 02:14:06 AM »
It just hit me, you would have to cut an weld the spring cups on the axle if you wanted to correct your pinion angle.   ::)
Offline robert_h
  • 30
  • 1.6 liters of fire-breathing power
« Reply #4 on: September 30, 2005, 04:34:39 PM »
With the axle rotation mod, the pinion points up at a sharp angle- does this create any problems with lubrication of the pinion?
My other question about that mod is: the lower u-joint is straight, but isn't the upper one still at an angle? Isn't it better if the two u-joints are at the same angle? Or do you use a CV-type driveshaft with this mod?
Thanks,   - Robert
« Reply #5 on: September 30, 2005, 04:40:33 PM »
Thanks,   - Robert
If you do a search of the forum you will find a diagram that shows how the angles work out the same. I don't think the diff angle is any worse than the front is after the drop brackets are fitted. I guess you just have to remember to jack it up to get the right amount of oil in.
« Last Edit: September 30, 2005, 04:43:27 PM by Rhinoman »
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #6 on: October 01, 2005, 01:54:50 AM »
the cal-mini kit has to keep some drive qualitys for the yuppies. (vibrations )over rotation makes for better drive shaft angles for the wheel in dude.   I maybe wrong in my thinking . stan
« Reply #7 on: October 02, 2005, 12:21:24 AM »
I've heard talk about rotating the rear lower
spring buckets, but I don't think this is a mod
that has to be done.
Lookat the front coils, they ride in a tinted spring
bucket in the lower A-arm, and I don't think I have
heard about any spring breakage ever, anyway just
the ramblings of a wild man
