94, 3speed auto
  • 15 Replies
  • 4223 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
94, 3speed auto
« on: March 23, 2005, 06:10:31 AM »
I was just wondering if anyone could tell me what my gear ratio is? and if you could couse any problems to the tanny if you change the gears manualy from Low, 2nd,and then to Drive Like a tiptronic tranny? Insted of just leaving it in Drive. Thanx again
« Last Edit: March 23, 2005, 12:48:55 PM by SunrunnerGT »
Sunrunner GT, Gold Trim Level
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 94, 3speed auto
« Reply #1 on: March 28, 2005, 02:35:02 AM »
Anyone?
Offline mahimahimo
  • 377
Re: 94, 3speed auto
« Reply #2 on: March 28, 2005, 08:14:34 AM »
yea im a little curious about that to
Offline Chief
  • 678
  • Whaddya lookin at??
Re: 94, 3speed auto
« Reply #3 on: March 28, 2005, 10:09:19 AM »
I think an auto is right around 4.60. And no, you won't get any benfit from shifting like a tiptronic tranny. You can only hold a gear by keeping it in that gear.
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: 94, 3speed auto
« Reply #4 on: March 28, 2005, 11:00:05 AM »
Unless somebody has changed something you should have 4.62's and I'm curious, why you would want to shift manually?
Offline mahimahimo
  • 377
Re: 94, 3speed auto
« Reply #5 on: March 28, 2005, 11:42:57 AM »
i wanna do it cause under heavey gas it shifts early in first and makes second gear even slower cause its in lower rpms
                               -mo
Offline TN_Tracker
  • 1113
Re: 94, 3speed auto
« Reply #6 on: March 28, 2005, 11:54:27 AM »
There's nothing wrong with occasional manual shifting but continuously doing it would raise tranny temps and decrease it's life in my opinion.
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 94, 3speed auto
« Reply #7 on: March 29, 2005, 11:59:50 AM »
I was kinda looking for the 1st gear ratio, 2nd ratio and then the 3rd. Thanks again.
Offline Agent Orange
  • 711
    • Trying to learn
Re: 94, 3speed auto
« Reply #8 on: March 29, 2005, 12:03:50 PM »
Automatic Transmission
Three-speed automatic
Torque Converter Lock-up
Gear ratios
1st 2.40
2nd 1.47
3rd 1.00
4th NA
Reverse 2.00
Transfer gear ratios
Low (4WD) 1.82
High 1.00
Differential ratio 4.62 (4.30 California)
  • 711
    • Trying to learn
Re: 94, 3speed auto
« Reply #9 on: March 29, 2005, 12:05:02 PM »
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 94, 3speed auto
« Reply #10 on: March 29, 2005, 12:09:06 PM »
cool thanx!   now my second quetion is, how well do they hold up to off-roading? I also herd that there wern't any bearings in the tranny but there are bushings, and that they never wear out. is this true?? Thanx
« Last Edit: March 30, 2005, 01:12:23 PM by SunrunnerGT »
Re: 94, 3speed auto
« Reply #11 on: March 29, 2005, 12:25:22 PM »
Horsepower (SAE net) 95 hp |removethispart|@ 5600 rpm
I knew we were high Hp ;D
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 94, 3speed auto
« Reply #12 on: March 30, 2005, 01:13:41 PM »
Offline SuzukHunter
  • 70
  • CAN YOU SEE ME NOW??
Re: 94, 3speed auto
« Reply #13 on: March 30, 2005, 02:20:27 PM »
i run a 3 speed auto  dont have the linkage to the motor for the auto shifting. so i have to manually shift all day long ,every day(havent had a problem). it will shift in to 2nd buy its self if i pour on the gas. it just wont shift in to 1st unless i manually do it. :)
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: 94, 3speed auto
« Reply #14 on: March 31, 2005, 04:07:23 AM »
how well will they hold up when they are taken off-road?
