Question on Auto Tranny
  • 15 Replies
  • 4258 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: July 29, 2005, 11:32:42 PM »
I recently picked up a 92 kick 4 door cheap. It has a 16 valve and an auto tranny. How do I tell if the tranny is a 3 speed or a 4 speed? there's no indication of an overdrive other than a switch near the gearshift that has N and P on it, which I assume is for Normal or Power mode. Is this an overdrive switch or a torque-converter lockup?
Offline cj
  • 1276
  • I drive a really big ATV
Re: Question on Auto Tranny
« Reply #1 on: July 30, 2005, 03:46:22 AM »
Should be and sounds like the 4spd but there should be a button on the underside of the grip on the trans shifter that you depress to activate/deactivate the overdrive and a light saying overdrive should illuminate on the dash.
Offline zaggy
  • 1134
« Reply #2 on: July 30, 2005, 09:57:34 AM »
The switch engage the overdrive If I remember correctly.
- Normal...overdrive mode
- Power...swithces to direct drive, no overdrive
Zag
Offline cj
  • 1276
« Reply #3 on: July 30, 2005, 03:08:16 PM »
Zag, the normal and power mode switch is seperate from the O/D and alters shift up and shift down points. It lets you hold more rpm before shifting up and kicks down earlier. On mine it works whether the O/D is on or off.
Offline zaggy
  • 1134
« Reply #4 on: July 30, 2005, 03:10:19 PM »
Which proves beyond the shadow of a doubt....
I don't know everything.....
Thanks CJ
Zag
Offline cj
  • 1276
« Reply #5 on: July 30, 2005, 03:18:32 PM »
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #6 on: July 31, 2005, 07:44:36 AM »
   Thats a 4- speed :-\  3-speeds have no buttons or anything 4-speeds are electronic and 3-speeds are old school  :)
At Lakeview Motorsports, were wasting your time already!
Offline Digger
  • 1991
« Reply #7 on: July 31, 2005, 10:15:57 AM »
Anyone know what R&P gears would be in the diffs? ???
Offline SnoFalls
  • 1358
« Reply #8 on: July 31, 2005, 11:23:15 AM »
4.62
Offline Digger
  • 1991
« Reply #9 on: July 31, 2005, 07:49:51 PM »
What would it drive like if I put the 4.62 thirds into a 5 speed Tracker on 215-75-R15 tires? Would it end up driving like it did with 5.12's and 31's or would it be better, just not rev as high on the road at 60?
Offline zaggy
  • 1134
« Reply #10 on: July 31, 2005, 07:58:25 PM »
Hey Digger
     Quick math on a napkin (can't find my calc) says it will be very similar to 31's with 5.12's.
But it's a 16v so you've got more power and torque to play with. As a hi way driver occasional off roader (like me) it would be a neat combo in my opinion.
Zag
Offline Digger
  • 1991
« Reply #11 on: July 31, 2005, 08:12:23 PM »
Actually I was thinking of putting the 4.62's into Silver to replace the 5.12 front I stole to fix the Goblin's exploded diff. Silver's a 5 speed with an 8 valve...
Offline zaggy
  • 1134
« Reply #12 on: July 31, 2005, 08:14:01 PM »
Thenit willbe much like the 5.12's with 31's I believe
Zag
Offline Digger
  • 1991
« Reply #13 on: July 31, 2005, 08:17:17 PM »
Hmmm... I live in the mountains... Anyone wanna trade a set of 5.12 thirds for my 4.62 thirds? LOL!
Offline explosivo
  • 3157
« Reply #14 on: August 01, 2005, 04:59:16 PM »
Have you found out if the trans is a 3 or 4 speed? A 4 speed will have 5.12's, IIRC.
omghi2.us[/url]
