Auto Tranny upgrades
  • 2597 Views
Offline biker
  • 730
  • It's a sickness I tell ya
« on: September 12, 2005, 08:11:44 PM »
I'm tossing around the idea of beefing up my auto a bit so I thought I'd ask here first.  What is available for aftermarket shift kits and such.  I called a local tranny shop and they wanted some stupid amount of money to do it so I thought I'd see what's available for parts or info. If anyone knows where to source these types of things or has a link to info I would greatly appreciate it.
This is for the 3 speed auto in a Tracker
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline cj
  • 1276
  • I drive a really big ATV
Re: Auto Tranny upgrades
« Reply #1 on: September 12, 2005, 09:02:37 PM »
Probably the best money you could spend would be on a transmission cooler if you don't have a decent one already and maybe look at using synthetic oil as heat is your biggest enemy.
« Reply #2 on: September 12, 2005, 10:35:26 PM »
Keep the ATF cool and clean, best bet
Other than that, the 3 speed is a TH180
it was also used in the Chevrolet Chevette (sp)
Shift and rebuild kits for those should work,
tho I have been told that there are 2 filter
styles, I don't know if this is a Parts house
problem, or if there were 2 different transmissions
in the TH180 line
Offline zooky
  • 135
« Reply #3 on: September 13, 2005, 04:25:39 PM »
I rebuilt mine, it wasnt that hard. There are NO high performance parts or shift kits available. I think the rebuild kit cost me $100, if you need any hard parts it will get more expensive
Offline SnoFalls
  • 1358
« Reply #4 on: September 13, 2005, 04:41:45 PM »
I think the difference between the th180n and th180C is the latter has the TCC lockup feature. I also think that after 1989 or so they are known as the 3L30.
here's a nice linky ... http://www.transtarindustries.com/FileStore/pdf/TH180_03w.pdf
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #5 on: September 13, 2005, 05:19:47 PM »
Yep
