Broke Front End, Diff, Third--Kick
  • 2520 Views
Offline Blurple90
  • 15
« on: September 30, 2005, 09:57:14 PM »
I just broke my Front differential, third member, or whatever its called!  I broke the housing clean in two.  Its in 2 pieces!  If anyone knows where i can get another one fast and cheap please let me know.  The axles are fine the housing is just cracked open all the way around.  Its a 1997 4dr 4spd Auto 16valve.  I need a Front end with 5.13s i believe.  I live near Elkin, NC 28683.  Any advice or parts would be greatly appreciated.  I really want to go to the Fall Zuwharrie net weekend.  Call my cell 336-366-9556.
Thanks, Alex
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: Broke Front End, Diff, Third--Kick
« Reply #1 on: October 01, 2005, 01:26:49 AM »
go bigger a 7.5 or a 9-inch both hy-bred of course the pot-metal front is not very strong.   hy-bred or the anvilis the only way to go. thats my opinion    stan
Offline jagular7
  • 1026
  • Jagular7
« Reply #2 on: October 01, 2005, 07:33:42 AM »
Did you broke the axle housing and not the 3rd member. The axle housing goes the width of your Trackick. The 3rd member bolts to the axle housing and is also bolted to the crossmember. It holds the ring and pinion.
I broke my axle housing in my XL7. The 3rd member was fine. When I took it all apart to replace it, I had damaged ring and pinion. I replaced everything with steel housing from a 02 5-sp XL7. I had to locate another ring and pinion as the trannys have different ratios.
Check http://car-part.com. Check locally, then regionally. I had to get mine from NY, I'm in KS.
Lenexa, KS
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #3 on: October 01, 2005, 09:08:18 AM »
I've always wondered what you trec/kick guys did about those Alum. fronts.
I know we Sami guys try and swap them into a steel housing to use them.  Although the Alum. housing IS pretty strong.
BTW, I have a complete front axel housing for a trac/kick here at the house that had 5.12's in it.  I just took the ring and pinion out of it.  You're welcome to it for shipping costs.  Just let me know!
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline Blurple90
  • 15
« Reply #4 on: October 01, 2005, 11:13:52 AM »
I broke the Third Member. Im new to 4wheeling.  Dont know what is damaged inside, i havnt taken it apart yet.  where are you located?
Offline purevil71
  • 261
« Reply #5 on: October 01, 2005, 08:12:55 PM »
Indiana...Let me know if you need/want it and I'll get ya the hook up.  I'll just send the compete assembly to get it out of my shed.
88.5 Samurai
I-Zook Staff
Offline Blurple90
  • 15
« Reply #6 on: October 07, 2005, 07:16:06 PM »
Thanks for all your help.  I got a complete 5.13 third member and axle housing out of a 22-spline tracker from Zukimon on the zuwharrie BBS board.  My ring and pinion were destroyed.  I swapped my 26-spline spider gears into the new third and installed it last night.  I also had to replace my radiator.  While i had it out, with the extra room, i did the timing and accessory belts and the cam and crank seal.  So far no problems.  I'll see yall at The Zuwharrie tommarrow!
Thanks again, Alex
Offline jagular7
  • 1026
  • Jagular7
« Reply #7 on: October 07, 2005, 08:19:58 PM »
Cool, great. Glad things worked out. Don't forget the camera......
Lenexa, KS
Offline ningram1
  • 84
  • 92 Tintop Vitara
« Reply #8 on: October 08, 2005, 12:32:08 AM »
steel front axle and third member is a good upgrade - if you can find one...
Chaos, Panic, Disorder. My work here is done.
