very high idle
  • 2157 Views
Offline karl214
  • 228
very high idle
« on: October 09, 2005, 12:12:11 PM »
Hey Guys,
 Just got my engines swapped out in my 90 Tracker,had to use my old intake and throttlebody on the newer engine"93" i think not sure.. Anyway when i fired it up it was idling around 3 grand, old engine would idle around 2 grand til it warmed up... What can i do to lower it down??? I've tryed turning the idle screw but that didn't help at all... Any IDEAS??????
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
  • 6598
  • 68
Re: very high idle
« Reply #1 on: October 10, 2005, 06:54:52 AM »
Hey Guys,
Are you sure you made the proper adjustment? There may be, check with your manual :) , two adjustments for idle. The warm idle adjust (that would be the real common one ) and an idle up or cold idle adjust. Maybe you adjusted the wrong one?
HTH, -Eric
Re: very high idle
« Reply #2 on: October 10, 2005, 02:35:51 PM »
Check the vacuum pipes around the throttle body. The idle up is engaged by default, the ECU switches the vacuum through to the Throttle Opener Vacuum Switching Valve (TOVSV) to disengage it. The TOVSV is at the front of the engine as shown in the pic below. if you have an early 8V you probably have two of these, the second is for the EGR valve. The vacuum pipe on the TOVSV comes from the manifold and then goes off to a plunger on the back of the throttle body. Like Eric said, that may need the gap adjusting.
« Last Edit: October 10, 2005, 02:40:15 PM by Rhinoman »
Re: very high idle
« Reply #3 on: October 11, 2005, 08:18:54 AM »
check for a too tight throttle cable,
it will hold the throttle open
Offline karl214
  • 228
Re: very high idle
« Reply #4 on: October 11, 2005, 02:58:43 PM »
That was the first thing I checked... Thanx ;D
