wheel spacers?
  • 10 Replies
  • 3888 Views
0 Members and 13 Guests are viewing this topic.
Offline zuki4fun
  • 91
  • luv machine
wheel spacers?
« on: October 13, 2005, 07:09:32 PM »
do wheel spacers up front  put stress on the wheel bearings on a sammy?
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: wheel spacers?
« Reply #1 on: October 13, 2005, 07:47:13 PM »
Nah everyone on here says they do but alot of people talk shit.
What wheels u running and offset. If u run a crazy offset and spacers yes they will
01 GRAND VITARA
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
Re: wheel spacers?
« Reply #2 on: October 14, 2005, 08:50:48 AM »
I've been having more problem's with my wheel studs that bearings.  If you do run spacers, BE SURE you uses some loc-tite and tighten your lug nuts properly.
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline JDMCRX
  • 1110
Re: wheel spacers?
« Reply #3 on: October 14, 2005, 09:39:29 AM »
First things first when u do wheel spacers.
Clean the grease off the wheels hubs and clean off with a wire brush. Thread chase the threads i believe its a 10mmx1.25mm then when all done spray brake clean and blow off.
To install the spacers apply Red loctite to the threads and tighten to 40ftlbs then 80ft lbs all in a criss cross pattern.
Ive had mine on for 20,000km still tight
01 GRAND VITARA
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: wheel spacers?
« Reply #4 on: October 14, 2005, 12:21:36 PM »
Anytime you push the wheels further out from the bearings you are adding stress to them. Imagine a wheelbarrow. When the wheel is in the center, it's easy to balance and the load is directly centered on the bearings. Now mount the wheel off to one side and try to move the wheelbarrow. It is almost impossible because of the offset of the weight on the bearing surface and the wheel...
Offline bus_driver
  • 479
  • the voices tell me different things
Re: wheel spacers?
« Reply #5 on: October 14, 2005, 12:58:48 PM »
how much of a spacer?   more space more stress !
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline SnoFalls
  • 1358
Re: wheel spacers?
« Reply #6 on: October 14, 2005, 02:10:13 PM »
If the question is do spacers (or for that matter non-stock BS wheels) put added stress on the bearings? ... The answer is ... Yes!
If the question is do spacers (or for that matter non-stock BS wheels) cause a problem with the  added stress on the bearings? ... The answer is ... Depends on who you ask!
IMHO, probably some life on the bearings is shortend, but these rigs are so light, I wouldn't worry about it (and plenty do it too).
Offline zuki4fun
  • 91
  • luv machine
Re: wheel spacers?
« Reply #7 on: October 14, 2005, 08:29:06 PM »
thanks for the info i dont know the back spacing right now but ill measure tomarrow.the reason i ask is beacause i have 33 14 boggers on ten inch wide rims and they rub on the leaf spring and the turning realy sucks.
Offline mrfuelish
  • 2862
Re: wheel spacers?
« Reply #8 on: October 14, 2005, 11:28:36 PM »
I think if you would of put that you had 33x14 boggers in the first posting you would have had some diffrent replys.  ;D
Offline roeman
  • 62
  • 1994 sammy!
Re: wheel spacers?
« Reply #9 on: October 15, 2005, 09:00:13 AM »
I have been running wheel spacers on my sammy for about 6 months now, i have had no problems with my bearings, i would say go for it, you can always get new bearings :D
1994 sammy
1995 Vitara 16v
Offline purevil71
  • 261
Re: wheel spacers?
« Reply #10 on: October 17, 2005, 09:28:27 AM »
There are guys in my club that go through more bearings running boggers than I have running wheel spacers and swampers (I have only had to replace one rear wheel bearing in three years).
So, if you run spacers AND boggers how are you gonna know what to blame (and therefore fix)?  Just automaticaly assume it's the spacers....???
88.5 Samurai
I-Zook Staff
