1.6 tracker- no power after rebuild
  • 29 Replies
  • 6313 Views
Offline b1pig
  • 61
    • Jeep
« on: October 13, 2005, 08:33:31 PM »
I posted some of this once already, but I got another idea.
Syptoms:
Engine runs rich. Black smoke when revving engine, "loads up" and runs very rough at idle, revvs s-l-o-w-l-y.
Anyone ever had the cam shaft a tooth off? I double checked the cam timing before buttoning everything up. It was dead on. Been thinking about removing all the stuff and checking it again.
Adding to that, I noticed that the ticking that I thought was a misadjusted valve, seems to be the fuel injector. It is pretty noisy. I don't recall it being that loud, either. Possiblity it is shot?
b1pig
'90 Tracker, '07 JK Rubi
Offline zaggy
  • 1134
Re: 1.6 tracker- no power after rebuild
« Reply #1 on: October 13, 2005, 08:41:48 PM »
I would think it's going to be something more basic....
- Check distributor timing and ignition system
- Check vacuum lines and MAP sensor
- Manifold vacuum leak?
- O2 sensor...code?
I would think it's likely on the accessory side (tune up kinda stuff) that you've got the problem.
The clicking is likely the injector, a number of folks have reported that they can be very noisy.
Zag
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #2 on: October 13, 2005, 09:59:06 PM »
ditto to what zaggy said - and i'll add
- coolant temp sensor
-fuel pressure reg(controled by vacuum)
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline b1pig
  • 61
    • Jeep
« Reply #3 on: October 14, 2005, 11:43:11 AM »
I've been all through the ignition system. The timing is on, the wires are good, the spark plugs good, the distributor cap and rotor were new right before I rebuilt the engine.
I haven't really considered a vaccum leak for the main reason being that most vaccum leaks tend to cause a lean condition. My primary problem is rich mix.. mainly off idle. I did the trick of plugging the idle air bypass due to the typical high idle start and fluctuating idle till warm. Again, this was done shortly before I rebuilt the engine.
I have no check engine light. The O2 sensor is new.
There are two coolant temp sensors, right? The temp guage never worked on the Tracker. The wire was broken off of it at the sensor. It never affected the way the engine ran.
I just also checked the vaccum with a vaccum guage on the little port about midway down the intake. Showed 11" of vaccum. Don't know if that Calmini cam is contributing to that or not, though.
b1pig
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: October 14, 2005, 01:07:47 PM »
Do you mean like "brand new"?
Because I would definitely be suspecting that.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: October 14, 2005, 01:43:16 PM »
ditto.  I had one brand new one go bad years ago right off the bat.
Offline karl214
  • 228
« Reply #6 on: October 14, 2005, 04:35:48 PM »
What is  the trick of plugging the idle air bypass due to the typical high idle start and fluctuating idle till warm?? Thats the same thing my engine does..
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
Offline b1pig
  • 61
    • Jeep
« Reply #7 on: October 14, 2005, 07:32:22 PM »
karl,
I ran accross a page somewhere that had picutes of what to do along with instructions.
There is a fast idle air bypass. It causes a "controled vaccum leak" when cold to run the engine speed up. There is a wax pellet in this vavle similar to that in your thermostat. It does fail, and causes a high cold idle anywhere from 2500-3000 RPM, then can also cause the idle to fluctuate or bounce between 1000-2500 RPM as the engine reaches operating temp, then go normal.
There is a small cover on the front passenger side of the throttle body that is held on with 3 screws. If you remove them, there is a round hollow threaded assembly. You need a peice of rubber vaccum of fuel line that fits snuggly inside that. I can't remember where I got th line, but I just snipped a small peice right off the engine where I had some excess length and it fit perfectly. Also, a small bolt that fits snuggly inside the line and will fit inside the cover. I did this, and replaced the cover. The einge ALWAYS idled around 1,000+ RPM and was unredictable. Once I did this fired the Tracker up, it shot straight to 700RPM and held steady. I have since adjusted my idle speed to read 1,000 RPM when warm. It tends to idle around 750-800 when cold. Not too bad.
Here is one like to some instuctions on the fix:
http://bbs.zuwharrie.com/content/topic,22023.0.html
b1pig
Offline zaggy
  • 1134
« Reply #8 on: October 14, 2005, 09:25:45 PM »
If your engine vacuum is that low I would be suspecting...
- Vacuum leak, on injected engines it can give false signal leading to rich conditions
- MAP sensor
- PCV
- Valve clearances
- Ignition timing
- Fuel pressure regulator
Wish i could see it, but these are best guesses.
Zag
« Last Edit: October 14, 2005, 09:27:17 PM by zaggy »
Offline b1pig
  • 61
    • Jeep
« Reply #9 on: October 15, 2005, 01:09:14 PM »
thanks, guys.
i really gotta quit taking on projects....  :-\
b1pig
« Reply #10 on: October 15, 2005, 02:50:29 PM »
Did you set up the cam timing with a dial gauge? It is not unusual for aftermarket cams to be ground a little off. If it is running very rich then maybe there is a problem with the fuel pressure sensor or the return pipe.
Offline b1pig
  • 61
    • Jeep
« Reply #11 on: October 15, 2005, 04:36:51 PM »
No, I didn't index the camshaft.... I don't have a degree wheel.
The more I thinkabout it, the more that it does seem to be a possible vaccum problem. Before I rebuilt the engine, there was very little vaccum. The brakes would loose boost if youpumped the pedal more than twice, and it could take a few minutes to build back up. The Transmission also did not like to shift into 2nd when cold. The engine would have to be up to operating temp before it would go into 2nd gear. After I rebuilt the engine and put it all back together, the cold-shift issue was gone... but within 50 miles, it returned.  ???
I don't get it.
I went out and pulled the vaccum line off the MAP sensor, and the idle dropped and the engine ran SUPER rough. Plugged it back in and ran good. I'll try starting it up cold tomorrow and see what it does.
b1pig
« Reply #12 on: October 15, 2005, 05:15:12 PM »
could be a pluged exhaust, something might of crawled up the pipe an died while ya had it appart, lol stranger things have happend.
Offline b1pig
  • 61
    • Jeep
« Reply #13 on: October 15, 2005, 06:00:52 PM »
Nah. Not possible. I had to cut the cat off when I put the Calmin header on it.  ;D
If anything... it is flowing TOO freely.
b1pig
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #14 on: October 15, 2005, 07:35:29 PM »
I would double check your timing belt marks. My 1.3 sami engine drove fine but no power after a rebuild. I didnt do it, I bought it that way. I assumed it was cause 1.3s just didnt have any power. Turns out after many many miles I had been driving one tooth off. I moved it over a cog and it worked fine. Still wasnt a race car but definatle had more power.
Mike
