Noisey Fifth Gear
  • 6134 Views
Offline Desert_Rat
  • Nothin but fun....
Noisey Fifth Gear
« on: October 20, 2005, 12:58:00 PM »
Being new to Suzuki's, A quick question..   When driving, my fifth gear makes a minor whine, (which I'm sure will get worse with time) and am wondering if it is the T-case or the gearbox... When stopped, I put the T-case in neutral, shift the trans into fifth, and get a whine on acceleration and letup.. On the road the same sounds are there, but easier to hear when I'm stopped.. Does anyone have experience with this??????
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Noisey Fifth Gear
« Reply #1 on: October 20, 2005, 02:24:21 PM »
It might be due to the fact that there is a Suzuki badge on the front of your vehicle.
Seriously though, every suzuki i've ever had has had either tranny or t-case noise.  I always believe it to be the tranny making all the noise, but as long as it still works (which it always still has), then i just keep going.
I think the actual 5th gear is a different type of cut to the others and just produces a different noise, but that's just my opinion.
1993 4-door Sidekick
4.24:1 t-case
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: October 20, 2005, 03:58:27 PM »
sounds like its a bad trans bearing.  :-\ if so 1-2-3rd will also make noise soon.
Mike
Offline 87transam
« Reply #3 on: October 25, 2005, 11:04:40 PM »
all of my gears make noise except for 5th, its not as loud.   is my tranny gonna blow up soon?
Offline toolman21
  • 229
« Reply #4 on: October 27, 2005, 06:56:24 PM »
Mine starting making noise.....couple months later a bearing came out of it, then the hunt for a new transmission began.  Check the grease and see if it looks like it has glitter in it, and make sure it is full of grease.  All you can really do is drive it till it break though...which could take a long time.
Toolman
Offline Dihnekis
  • 398
« Reply #5 on: October 27, 2005, 07:44:06 PM »
Time for a rebuild sounds like. Mine whines in every gear except 4th (1:1), but I've got another transmission sitting in my garage waiting until this one explodes, or I do my 1.6 swap which ever comes first. I'm hoping on the 1.6 swap, mostly because I don't want to do the same work twice.
1988 Suzuki Samurai
Offline Autobot
  • 189
  • Danger Can Happen!
« Reply #6 on: October 30, 2005, 09:24:45 PM »
 I've got a whine on mine in 2nd gear (sometimes 3rd) but only around 2500rpms. Right before and after 2500 it's fine. Is that something to keep an eye on? Like some had mentioned, could it spread to other gears?
Got Tracker?
2000 2dr. convertible, stock.
Offline Dihnekis
  • 398
« Reply #7 on: October 30, 2005, 10:23:57 PM »
Autobot, start looking at rebuild kits or rebuilt transmissions. You are gonna need one eventually, could last another year could last a week.
1988 Suzuki Samurai
« Reply #8 on: October 31, 2005, 11:04:41 AM »
  I heard there was a gear virus running around, or maybe that was the bird flu ?
