hesitation help PLEASE!!!
  • 9 Replies
  • 3366 Views
Offline 90Stomper
  • 427
« on: March 14, 2005, 10:02:06 AM »
i am getting HUGE hesitation when ever i move the peddle more that 1/4" at a time, to the point of it almost dying if i kinda punch it.  what i have tried:
change out and adjusted tp sensor - no help
changed out idle speed control sensor - no help
put in new fuel filter - helped about 50%
wax pellet put back in - no help high idle
   took back out and pluged - better idle still hesitates
changed out injector - no help
checked timeing - right on +20*
checked plugs and cleaned - no help
wires plugs cap rotar coil and vlines all new.
HELP!!!  this sucks.
could it be a loose timing belt, bad fuel presure reg, fuel pump?  since changeing the fuel filter helped it must be something having to do with the fuel? :-/ :'( :-[ >:(
thanks all!
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline locjaw
  • 2045
  • 22
Re: hesitation help PLEASE!!!
« Reply #1 on: March 14, 2005, 10:17:55 AM »
Im not a EFI expert but I would check fuel pressure. I dont know exactly what it is supposed to be but someone out here will
good luck with it
jason
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #2 on: March 14, 2005, 11:23:02 AM »
Yep, sounds like the pump is having a hard time keeping up with the go-pedal.
Offline 90Stomper
  • 427
« Reply #3 on: March 14, 2005, 01:39:08 PM »
i am looking up how to do that right now.  anyone have experence checking fuel presure or changing out the pump?
Offline TN_Tracker
  • 1113
« Reply #5 on: March 14, 2005, 04:38:10 PM »
36 PSI for an 8V TBI engine,
should be close to that to 43
PSI depending on the EFI system
Offline 90Stomper
  • 427
« Reply #6 on: March 15, 2005, 04:21:54 AM »
cool, but, (always a but) where and how much is the guage ganna cost me,  i just looked up pumps at autozone  :o  very pricy.  was thinking about just taking out the pump and cleaning it first, what ya think?  maybe the inlet is pluged.... ???
« Reply #7 on: March 15, 2005, 04:40:19 AM »
check your temp sensor and make sure your engine warms up all the way.(gauge comes off of the cold side.)
Offline TN_Tracker
  • 1113
« Reply #8 on: March 15, 2005, 07:52:57 AM »
I'd get a garage to check the fuel pressure, it shouldn't cost much.
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #9 on: March 17, 2005, 05:14:37 PM »
if changing your filter helped than you might want to remove the pump assembly and check that the strainer on the bottom of the pump is not plugged with crap - you could have got some bad gas maybe?
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
