Putting seafoam in an EFI
  • 16 Replies
  • 5225 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: November 17, 2005, 09:07:51 AM »
Hey all,
So I've got some seafoam and I want to clean out my intake. I understand that I should be able to unhook a vacuum line, and basically suck seafoam out of the bottle into the intake with it, and then let it sit and foam up.
My question is, what is the best vacuum line for this? What is the best way to do this? Is what I'm talking about feasible?
(16 valve for those not in the know)
Thanks!
Heather Galvin
Re: Putting seafoam in an EFI
« Reply #1 on: November 17, 2005, 11:33:05 AM »
When I did mine I pulled the hose off of the Idle air conrtol vavle and sprayed it down the hose(yes mine was a spray can)while giving it some gas and keeping the rrrrrrrr's up.
Offline chet
  • 556
  • Zuki time!
« Reply #2 on: November 17, 2005, 12:41:14 PM »
brake booster vacuum is the one I used.
Offline 94track
  • 212
« Reply #3 on: November 18, 2005, 03:42:47 AM »
I second the brake booster, I use that hose on almost all vehicles I seafoam
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #4 on: November 18, 2005, 03:33:54 PM »
So did you do it yet?  Looking for results/differences/damages...
1993 4-door Sidekick
4.24:1 t-case
mudfkr
« Reply #5 on: November 18, 2005, 05:57:50 PM »
What is seafoam ?   ???
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #6 on: November 18, 2005, 06:46:18 PM »
mudfkr
« Reply #7 on: November 18, 2005, 07:56:08 PM »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: November 20, 2005, 09:30:05 AM »
No, not yet, ;)
Soon! Maybe today!
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: November 21, 2005, 06:31:26 PM »
Sorry for not replying sooner, guys. :)
I put the seafoam in yesterday using the brake booster line.
Definately some extra pick-me-up. Kind of like putting in new spark plugs.
I had fun zooming down the road for a little bit smoking people out behind me.  ;D
Heather Galvin
« Reply #10 on: March 28, 2009, 02:59:52 PM »
This is the 10th manufacturer of efi i've used seafoam in.  It works grrrreat! Jjust like the other 9!
Doesn't harm the polymers at all!  Alcohol base products don't work !/2 as well & deteriorate the polymer lines & components.
« Reply #11 on: March 28, 2009, 06:51:49 PM »
Where would I put this into on a 1.3L sami 8v
Offline Swansen
  • 64
« Reply #12 on: March 28, 2009, 06:55:52 PM »
I used it, and my engine is pretty dirty, i think PO didn't change oil at some point, anyways, i ran it for like 20mins, maybe 15?? but i did't notice any difference, half into crankcase other half into intake.
« Last Edit: March 28, 2009, 09:27:28 PM by Swansen »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #13 on: March 28, 2009, 08:02:00 PM »
Pour it on the ground and do a burnout on it and you will have all the smoke without the harm to the eng! >:D
   Kevin
     Go find some shop that uses BG products and buy a can of 44k and put it in your tank
« Reply #14 on: March 28, 2009, 08:56:15 PM »
BG Products? Anymore info?
