Crown Vic shocks on a Sidekick..??..I heard about this....what about them?
  • 10 Replies
  • 3442 Views
Offline THORSZUKI
  • 32
I read somwhere Crown Vic shocks fit on a Sidekick.
Is this true and what is the benefit..are they cheaper....Longer.....extened more....if it is a good thing do you order the same year as your Kick?....anyone know about this it would be good info.
CANADA TRUE NORTH STRONG AND FREE
Offline pcguy
  • 343
  • 1996 Tracker 4x4
it is my understanding these are best when used on the rear of the vehicle when installing spring spaces and doing the strut mount flip trick. I think the goal here is to give a little bit of extra down travel in the rear suspension to prevent it from banging into the end of the shocks when hitting the top limit of the rear suspension
You can only do the Crown Vic shocks
if you want your Track/Kick to look like this
Offline suzukikid
what years do you guys recomend to use
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Check these links:
http://www.zukiworld.com/forum/index.php?topic=9146.0
http://www.zukiworld.com/forum/index.php?topic=809.0
http://www.zukiworld.com/forum/index.php?topic=8693.0
And the list goes on and on... just use the search button above and type in "crown vic" You'll get plenty of answers! LOL! ;)
Offline THORSZUKI
  • 32
anyone have some specifications, I have 1.5 inch coil spacers waiting to be install this looks like a good add to it.
Offline Digger
  • 1991
Just click some of the links I posted! LOL!
All the info you could possibly want is contained in them!
I used 91 crown vic shocks and they measure 1-1/2" longer than stock, mount the same way as stock and are $5 cheaper each than stock (when purchasing Monroe Gasmatics at Advance) and they are perfect with 1-1/2" spacers. ::) ;D
Offline THORSZUKI
  • 32
Thanks a ton the information is perfect :)
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
Im using a pair of Monroe Sensatracks from a 91 Crown Vic.   Unreal soft ride from the back. best money ive spent.
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
Offline derekj
  • 784
  • i'm the canadian guy eh?
rear shocks off a 93 e150 work well too. they are 2" longer than stock.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
Depending on the size of your lift, Rocky Road has doetch tech shocks that will fit and provided extra travel. Check out the article on the rocksteady kit in the gear guide section.
