tp sensor
  • 9 Replies
  • 2854 Views
Offline mahimahimo
  • 377
tp sensor
« on: November 29, 2005, 08:10:32 PM »
so finally after a few weeks of thinken it was my o2 sensor ....i ran the codes and i got that back ... tps sensor ...wtf is it and how much is it lol ....i would greatley appreciate any help...thanx
                                                              -mo
Re: tp sensor
« Reply #1 on: November 29, 2005, 09:24:26 PM »
8V or 16V engine ???
TPS is Throttle Position Sensor
and it located opposite side of
where the throttle cable is, usually
Offline mahimahimo
  • 377
Re: tp sensor
« Reply #2 on: November 30, 2005, 07:08:17 AM »
its an 8v......
Re: tp sensor
« Reply #3 on: November 30, 2005, 01:08:32 PM »
Offline mlovetripp0
  • 204
  • do more with less
Re: tp sensor
« Reply #4 on: December 02, 2005, 07:55:32 PM »
is there a way to check your  tp sensor with a ohm meter?
87 sammi
Re: tp sensor
« Reply #5 on: December 02, 2005, 09:27:49 PM »
Yes, but if there is alot of miles on your rig I would replace it,also check your butterfly shaft that hooks to it for play.
Re: tp sensor
« Reply #6 on: December 02, 2005, 11:24:39 PM »
8V TPS is not a smooth sweep on the
Ohm meter, it's more of a switch that
tells the computer when you are off idle
and at WOT, so don't expect to see a
meter reading like a Pot would show
Re: tp sensor
« Reply #7 on: December 02, 2005, 11:30:42 PM »
That sucks, how many wires are on the 8v tps? my 16v has three.
Re: tp sensor
« Reply #8 on: December 02, 2005, 11:37:50 PM »
3 or 4, I don't remember
Re: tp sensor
« Reply #9 on: December 03, 2005, 08:44:43 AM »
I think that only thevery early models had that arrangement. Mines an 8V and mine has a pot and an idle switch, FSM shows it as a pot too. You can see in the pic below that there are 4 wires, Jap models have 5 wires
You can test it with an ohmmeter, although I found that the wire colours on mine don't match those shown in the FSM. Have you looked at the diagnostic stuff here:
http://www.suzukiinfo.com/vitara/1994-G-TestsWithCodes-1.6L-TBI.zip
« Last Edit: December 03, 2005, 09:19:57 AM by Rhinoman »
