newbie to webers, got some questions
  • 2402 Views
Offline 94track
  • 212
« on: December 10, 2005, 03:51:50 PM »
well i finally got my tin top in the garage today, and this carb needs some work, first question where do i run the 2 choke lines to, any pics on this one would help a ton
second where do i run the hose to from this brass 90 fitting
any help would be appreciated
« Last Edit: December 10, 2005, 04:58:12 PM by 94track »
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: newbie to webers, got some questions
« Reply #1 on: December 10, 2005, 06:03:20 PM »
One of mine is connected to a nipple on the intake manifold on the side facing the firewall very near the vacuum line to the brakes.  I think the other one attaches to the coolant manifold that comes out of the back of the waterpump and runs down the side of the engine.
If you can wait til tomorrow, I can tell you exactly how mine are connected. Too danged dark and cold right now.
The resulting setup works best if the choke water inlet and outlets face the firewall.  If you have the choke set (probably not, I bet -- but why add another variable to the mess?), unscrew the bolt on top (11 mm) and turn the housing so as to not disturb the choke setting which is made by loosening the three 7 mm hold-down bolts and rotating the housing that way.
Yes, I have been on the phone to sarge recently...  There may be a second part of the Weber Tuneup article at iZook.com covering choke adjustment.
Ack
Offline newmexicocrawler
« Reply #2 on: December 10, 2005, 07:55:46 PM »
ask sarge. hes the gurue he WILL have the answer
Offline 94track
  • 212
« Reply #3 on: December 10, 2005, 09:56:29 PM »
Sarge got me all straightened out.  Thanks for the replies fellas
