Help! 1.6L 16 Valve Injector Specs?
  • 34 Replies
  • 8309 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
« on: December 13, 2005, 11:49:11 AM »
Can anybody tell me the specs on the injectors in a 16-valve MFI injectors?  Specifically, pounds per hour rating, opening and closing time in milliseconds?
I doubt that they're the same as the injectors in an 8-valve!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline cj
  • 1276
  • I drive a really big ATV
Re: Help! 1.6L 16 Valve Injector Specs?
« Reply #1 on: December 13, 2005, 12:29:03 PM »
Injected fuel volume:
38 - 48 cc/15 sec. (1.28/1.34 - 1.62/1.69 US/Imp. oz/15 sec)
mudfkr
« Reply #2 on: December 13, 2005, 12:50:26 PM »
CJ, Did you know that the Jap Helly Hansen model  Escudo have bigger Injectors and bigger Throttle bodies and a different ECM  ;)
« Reply #3 on: December 13, 2005, 01:23:32 PM »
In the states we use cc/min or Pounds /hr
They should be aprox 17 PPH and have an
opening time of about .8-1.0 millisecond
So Bob, are you setting up and tuning the
MegaSquirt ???
Have fun, Wild
« Reply #4 on: December 13, 2005, 01:42:23 PM »
Do you know the impedance of those injectors? I noticed in the Jimny manual that it has high impedance injectors. It is also MPI with a MAP sensor.
Wild, did you get any opening times for the 8V injector at different voltages?
« Last Edit: December 13, 2005, 01:44:27 PM by Rhinoman »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: December 13, 2005, 01:50:01 PM »
Darrin - the 1.28 - 1.34 Oz per 15 seconds that cj posted - that's 19.2 - 20.1 pounds per hour.  Hmm.
Yeah, but I'm really seriously looking at jumping in with MegaSquirt-n-Spark all at once, and using the factory harness (I have an ECM connector, I am adapting to the DB37).
The V3 PC board has high current drivers, and flyback stuff all on-board.
Bob
« Reply #6 on: December 13, 2005, 01:55:30 PM »
The MegaSquirt never powered the 8V injector,
I think the 8V injector to be lowZ and 50 PPH
Opening times are pretty typical, and the baseline
used is aprox 1 millisecond, anything lower than
this is questioned by the MegaSquirt program, which
uses the opening/closing time as part of the overall
time in Ms of the injection pulse, giving too long of
an estimated o/c time will be of little trouble with
stock injectors, but with large capacity injectors,
could really cause an over rich idle
Offline cj
  • 1276
« Reply #7 on: December 13, 2005, 02:02:09 PM »
Tell me more  :) By the way I learnt that the earlier 16v has a bigger intake and AFM and it gives more performance  ;D
« Reply #8 on: December 13, 2005, 02:04:38 PM »
At 19 to 20 PPH would explain why the
16V turbo conversion works so well with
the stock ECU and injectors.
V3 board sounds like the way to go, I use
the current limiting settings to skip the
resistor packs, so far that seems to work fine,
time will tell, but the transistors don't even get
warm so I think it's working OK
« Reply #9 on: December 13, 2005, 02:32:42 PM »
Does v3 still use the Dtype? usually they are only 5A rated so its pushing it a bit if you run high rpm a lot.
« Last Edit: December 13, 2005, 02:36:18 PM by Rhinoman »
« Reply #10 on: December 13, 2005, 02:38:20 PM »
I will test my spare injector when I get a chance but I don't have a power supply that can supply enough current at home.
« Reply #11 on: December 13, 2005, 09:19:43 PM »
I can get you TBI Ohm readings,
TBI isn't in much use now   :(
mudfkr
« Reply #12 on: December 14, 2005, 01:55:32 AM »
I'm picking up a H/Hansen 16v Motor a 4spd auto next week to put into a mates Sammy I'll check it out for sure and let you know. ;)
« Reply #13 on: December 14, 2005, 04:41:36 AM »
TBI injector is 0.8 to 1.8 Ohms, I was looking for the impedance of the 16V injector. I haven't got the specs for those.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #14 on: December 14, 2005, 07:55:57 AM »
According to the FSM, they're somewhere between 10 and 17 ohms...  Can't remember exactly, but definitely considered Hi-Z injectors.
Bob
