carb problems/ anyone selling a weber
  • 1923 Views
Offline chance_S
« on: March 09, 2005, 08:18:52 AM »
i have a 87 samuria with a stock carb and it wont idle under 1500 rpm so i got the idle screw cranked out so i can drive it. if u have any idea how to fix this other then a weber (seeing how they are on strike) please help. i have checked for vacumn leaks there are none.
if you are sellin a weber for a samuria for under 400 dollars please let me know i will gladly buy it from you if its pretty new
« Last Edit: March 10, 2005, 07:57:03 AM by chance_S »
  • 6598
  • 68
Re: carb problems/ anyone selling a weber
« Reply #1 on: March 09, 2005, 08:42:20 AM »
if you are sellin a weber for a samuria for under 450 dollars please let me know i will gladly buy it from you if its pretty new
Are you aware that there are three adjustments that can effect your idle speed? There is the cold / fast idle adjustment that is the more obvious adjustment at the back of the carb close to the cable pull linkage. The warm idle adjustment is also at the back of the carb but is tucked underneath a fair share of hoses and is located at the baseplate of the carb. The third place that could be effecting your idle is the idle up circuitry adjustment. The idle up / accessory on idle adjustment is a large(ish) bolt located at the back of the carb that a vacuum plunger pushes on to idle up the vehicle whenever an accessory is turned on (lights, heater) or you are above a certain altitude.
Try checking and/or adjusting (if needed) these first.
But wait! Do you have a vacuum leak? Did this problem just start happening? Check for crack/broken/misfitting hoses and possible leaks at the baseplate of the carb..
Good Luck, Eric
PS. Wasn't there a thread on here that had some carb pictures? I seem to recall there was.... Anyone remember?
Offline ROSS
  • 1412
« Reply #2 on: March 09, 2005, 12:59:28 PM »
THE CARB PICS WERE  EFI. I HAVE A WEBER TWO YEARS OLD . WORKS GOOD.  $200.00 WHERE YOU LIVE? WENT TO EFI. IT EVEN RUNS UPSIDE DOWN.
                                          ROSS
Offline HUMZUKI
  • 117
  • Fool!
« Reply #3 on: March 10, 2005, 12:48:55 AM »
Dude,,,,,There not $450 new. ::)
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: March 10, 2005, 03:08:16 AM »
Now that is a confusing statement!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
